2016 ES300h Aftermarket Tire Specs Helps
Old 11-19-16, 07:59 AM
RJP62
RJP62's Avatar
Default 2016 ES300h Aftermarket Tire Specs Helps
Hello,
I found a set of IS F Sport wheels that are 18x8 with a 35mm offset (oem 17" is 45mm). Looking very hard at Michelin Pilot Sport A/S 3+ to wrap them in. Size 225/50. +.7% dia., 9.2" section width.
I would like to hear from an expert weather or not if this size tire and wheel combination with that offset difference will cause any rubbing issues? I understand that the speedo will be off a little because these are technically .2" taller tires but I believe +.7% is within the allowed limits.
Thank you very much.
Rob
is250san
06-27-16 08:28 PM
gerbjones
02-15-09 09:03 PM
gx470man
GX - 1st Gen (2003-2009)
08-28-08 11:31 AM
dle
02-25-07 08:20 PM
hiyabrad
01-26-03 10:35 AM
Quick Reply: 2016 ES300h Aftermarket Tire Specs Helps
