Help (stock rim sizes on the oem gs300)
Old 01-17-05, 08:58 PM
ARISTO 161
ARISTO 161's Avatar
Default Help (stock rim sizes on the oem gs300)
what is the stock rim sizes on the oem gs300?
im asking for the 16x??
and what are the widths for tires that can fit on it? ???x??x16
thanks for the help guys
Old 01-17-05, 09:27 PM
Neo
The One
Neo's Avatar
The 16s are 16x7.5.
The 17s are 17x8.
The biggest tire I'd comfortably put on the 16s are 235s but 225s would be good..
Old 01-18-05, 01:11 AM
rominl
exclusive matchup
rominl's Avatar
yeah on a 7.5 i think 225 is what i would go for
Old 01-18-05, 03:56 PM
ARISTO 161
ARISTO 161's Avatar
Default ok ..
so their 7.5's....
well thats not really good performance wise isnt it?
Old 01-18-05, 06:33 PM
KRGS4
KRGS4's Avatar
With my stock rims 16X7.5 (50mm offset)...I ran 245/50 16 Pirelli PZero Nero M&S last year.
The fit was perfect, no rubbing, event at full turns (I am lowered 1.5 by the L-Tuned Springs/Shocks). This gave the car a Fatter look all around. The Lexus ride was still there.
the car felt quicker as well because of the shorter overall diameter + 245 footprint.
Chicago winters have me running 225/55 16 Dunlop Winter Sport M3s and the look is back to the "regular guy" look.
245/50 will fit with no problem. + sweet look...
Old 01-18-05, 09:50 PM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by ARISTO 161
so their 7.5's....
well if you talk about performance, if you can get some wider rims with wider tires it's only going to help
Old 01-19-05, 03:46 PM
ARISTO 161
ARISTO 161's Avatar
Default o
i can fit 245's on the rim??
what does that look like?
Old 01-19-05, 04:00 PM
ARISTO 161
ARISTO 161's Avatar
Default o
why are 215/40/16 $30 more than the 215/60/16
and which are better...
thanks for the help guys, im trying to gain knowledge since i need new tires soon
and i might consider rims..
after going to the track, i found out that my nitto 460 215/60/16's are too slippery...
the prices
Old 01-19-05, 08:05 PM
Neo
The One
Neo's Avatar
Since KRGS4 did it on his, apprently it will "fit". I would not do it since the rim width and tire width has a bigger diference than I'd like. Ultimately, it is your car so you can make the call.
As for 215/40? Why that size? It will make the wheel outside diameter too small compare to the OEM 215/60. I really don't see any benefit other than you are going to be lowered a little but that is not the best way to do it.
Old 01-20-05, 06:40 PM
ARISTO 161
ARISTO 161's Avatar
Default haha
hmm seems like the ones with less height have faster speed rating
yea, i dont want any lower, im already too low haha
but if thinner is more performance its seems more worth it no?
Old 01-20-05, 07:06 PM
Neo
The One
Neo's Avatar
More performance, worse ride.
Anyway, if you are planning on OEM 16, I'd stay with 225/55 or if you want to push it 235/50 (although this is not optimal). If you want to play on the wild side, then 245/50 like KRGS4. The 245/50 is actually a better size in terms of diameter. It is closer to OEM spec but on a 7.5 rim, I'd be hesitant to put it on.
At the end of the day, though, it is your car and your call.
The 40 series is more performance oriented but in order to effectively run that size, you really need to be running 18s.
Old 04-25-11, 03:26 PM
rah1722
rah1722's Avatar
I have 225/55R/16 (my kids car) `1993 GS300 I am asking how less in width (225) can I go and convince him it's still looks wide
Old 03-15-15, 09:10 PM
NoUltimatu
NoUltimatu's Avatar
Sorry about reviving an old thread, but I would really need some bigger tires than my 225 bf goodrich tires and wanted to go to 245. Would I rub at full lock without spacers?
OneGuyInCA
RX - 1st Gen (1999-2003)
03-13-08 07:41 AM
Jace7
01-31-07 12:40 PM
roguenode
10-13-05 01:19 PM
Mrbig
18
03-28-05 08:44 AM
Quick Reply: Help (stock rim sizes on the oem gs300)
