Installed Supra TT front brakes w/cross drilled rotors.
Old 10-06-03, 10:46 AM
Anthracite SC
Anthracite SC's Avatar
Default Installed Supra TT front brakes w/cross drilled rotors.
Hey I just installed supra TT front brakes. The 4 piston calipers w/metal master pads and cross drilled rotors. These things are HUGE. Anyhow..it's a BIG difference compared to the old lexus 1 piston calipers I had before.
I recommend this change for anyone who wants to improve their peformance. Getting the supra TT brakes is a MUCH cheaper alternative to 3500 hundred dollar brembros.
Old 10-06-03, 11:18 AM
sc300tt
sc300tt's Avatar
I agree 100%. The Supra brake upgrade is one of the most enjoyable, best bang-for-the-buck upgrade I have done. The only reasons to go to an aftermarket brake setup is because:
1. You want it to look pimp and having $100's laminated into your hood might look tacky.
2. You are making well-over stock hp and road race the car competitively.
Supra brakes with STOCK rotors and a quailty aftermarket pad is more than sufficient for 100% of street driving and 99% of track use. The cross-drilled pads are nice for street use since they look "racier", but will only crack under severe use on the track. If you fall into that 1% that needs the bigger setups, you shouldn't mind spending the multiple hundreds per rotor and per set of pads. I know I dont fall into that group, at least not unless I One-Lap either car.
Old 10-06-03, 12:21 PM
Lex Luthor
Lex Luthor's Avatar
Haven't had any problems with TT-size slotted rotors though.
Old 10-06-03, 12:47 PM
sc300tt
sc300tt's Avatar
Slotting havent produced any cracking problems that we have seen.....Havent produces any shorter stopping either. But they definately look cooler. Hard to beat those $60 stock ToyCo Rotors.
Old 10-06-03, 01:16 PM
FaceUT
FaceUT's Avatar
So, how much did you wind up spending on the upgrade? Will the Supra Brakes fit within the GS400 17" wheels?
Old 10-06-03, 02:51 PM
jet864
jet864's Avatar
Doubt it. i think you have to have something as wide as the Supra wheels and I don't belieev any OEM Lexus rims will work.
James
Old 10-06-03, 03:13 PM
00GS400L
00GS400L's Avatar
They won't fit on factory 17's on the GS. TOO BIG
Old 10-06-03, 06:34 PM
Anthracite SC
Default 18 inch wheels a must for these
Yes..these are the best bang for the buck
I do have the stock rotors and will use them. It's just that I got a great deal on the cross drilled ones and would just match the rear ones.
It is SUCH a difference..these TT brakes. Wow..if I actually had POWER..I could appreciate them more =)
I got the front brakes for 475 bucks...for the set
Old 10-06-03, 10:21 PM
skpark70
skpark70's Avatar
Wow it sounds great....
Could you tell me where did you get your brakes at?????
Old 10-07-03, 12:36 AM
mrshabo
mrshabo's Avatar
i have some 17's that i'm gonna be putting on the winter. i'm not sure if they are gonna fit do you guys know what u need min for them to fit?
Old 10-07-03, 08:54 AM
sc300tt
sc300tt's Avatar
Default Re: 18 inch wheels a must for these
Originally posted by Anthracite SC
I do have the stock rotors and will use them. It's just that I got a great deal on the cross drilled ones and would just match the rear ones. ...
Well, I wouldnt change out the x-drilled ones if you are just gonig to drive it on the street as they should be fine, I was refering to them being a problem with a car that is taken to the track for 15-20 minute sessions.
Old 10-07-03, 09:21 AM
Anthracite SC
Default Bought them from a mmber on the forum
I bought the brakes from another member on the forum who had em for his supra but upgraded to aftermarket brakes and gave me his spares.
I haven't seen TT brakes in that price range anywhere...usually in the 800s with labor
Old 10-07-03, 09:50 AM
mrshabo
mrshabo's Avatar
i just bought mine for 400 shipped. THe front and rear calipers including pads and bolts. I could have gotten the rotors too for 75 bucks but i'm getting slotted cross drilled so i told them i didn't want their rotors. This is all used of course. 52 thousand miles off of a 98 supra tt.
Old 10-07-03, 10:29 PM
mrshabo
mrshabo's Avatar
hey u guys know how much the slotted cross drilled brembros run for new? i can't seem to find the price on them. i believe these are the ones you have on your car anthracite
Old 10-08-03, 07:08 AM
hemogoblin
hemogoblin's Avatar
Hey Clint,
Are those moda r6's on your car? They look real good. Im about to purchase a set, but I dont know what spec 19"s to get. Did you have any probl***s with yours? and, those are 19" right ?
Quick Reply: Installed Supra TT front brakes w/cross drilled rotors.
