Tire pressure-adjust according to tire or car specs?
Old 09-09-03, 09:48 AM
mjr24
mjr24's Avatar
Post Tire pressure-adjust according to tire or car specs?
I just put on a set of SC430 rims. Should the tire pressure be kept at the specs of the tire....or of my car, SC400? I think car specs is 32 psi, while tire is alot more.
Old 09-09-03, 10:12 AM
SC300Es
SC300Es's Avatar
I think the tires list the maximum pressure. you should go with 32-35psi
Ed
Old 09-09-03, 01:17 PM
ATSOU
ATSOU's Avatar
I think the tire pressures are vary from the thickness of your tires...........18's should be at around 40-42 psi
Old 09-10-03, 05:53 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Tire Pressure
If the upsize was done correctly there should be about the same volume of air and therefore you would run exactly what the door jam says to run. The tire sidewall lists the maximum inflation pressure before the tire is in danger of rapid deflation
Inflation Pressure
lexman52
11-29-15 02:04 PM
Rustito
11-01-14 08:53 AM
HAiS250
09-21-11 05:27 PM
felixsc300
01-13-09 02:17 PM
uae
03-10-08 09:16 AM
Quick Reply: Tire pressure-adjust according to tire or car specs?
