Max tire and Rim size for GS????
Old 07-19-03, 12:39 PM
nima
nima's Avatar
Question Max tire and Rim size for GS????
Hey guys,
What’s the max tire/rim size I can put under my '02 GS300 without touching the suspensions? Would
like to have 8.5 fronts and 10 rears.
Any help is appritioated.
Old 07-19-03, 01:14 PM
J.P.
Boardroom Thug
J.P.'s Avatar
Search shows about 900 threads with the answer.
To answer your question, here is a thread with 70 posts, every combo you can think of.
https://www.clublexus.com/forums/sho...ght=tire+sizes
20" - 8.5 up front and 9.5 to 10 in the rear seems to be the majority there days. Running a 245/35 and a 275/30 will do the trick.
Old 07-19-03, 01:52 PM
nima
nima's Avatar
Thanks, but the problem is that this is my primary ride and i drive about 50miles aday. I 'm looking for something in the 40/45's without a drop.
Old 07-19-03, 02:05 PM
Received 2,127 Likes on 1,379 Posts
Then your needs will produce bad results. For better ride/comfort stay with no bigger than 18's, but 18's with tall tires and no drop will look bad.
I have a 'fat 19' setup, 245/40-19 and 275-35-19 and the ride isn't bad but I only drive 20 miles a day (10 each way). If I had to drive 50 miles a day I'd get an LS430.
Old 07-19-03, 02:12 PM
J.P.
Boardroom Thug
J.P.'s Avatar
Yeah without a drop, bit is right, run the 18's, even then it may be to tall but I have seen it done before if you pick the right size tire.
A lot of people on here rock the 18's, may be rough compared to the 16's but it should have enough tire on there to ride pretty good.
Old 07-19-03, 02:43 PM
nima
nima's Avatar
Do you have any drops/ or stock?
LexiGS
09-28-09 09:01 AM
dle
07-06-07 03:57 PM
ktang235
12-20-05 09:40 PM
a33max
08-19-04 12:17 PM
NYlexus
21
12-18-03 03:59 AM
Quick Reply: Max tire and Rim size for GS????
