Couple of ???
Couple of ???
First one is I'm going to get some 20's for my 98 gs400 and I'm going to lower it with the eibach prokit which I believe lowers the car one inch all around. The tires on the wheels will be 255X35. Will there be any rubbing at all?
Question two is I just installed some day time running lights and while I like the color a lot more than the factory yellows, they aren't nearly as bright. What would you guys recommend as far as getting a bulb that has good intensity and color for daytime runners, thanks.
got a buddy with 255/35/20 upfront and he still has stock suspension and rubs on highway highlows, but u need 2 make sure u get the right offset, i think +44 to +40 is about right, mayb one of the wheel gurus will give u the xact offsets that will claer fine, just cus its 5 lug doesn't mean in will fit....
Re: lights?
Originally posted by WiLlNyC
HOW DO YOU GET THE DAY LIGHT RUNNING LIGHTS?
what yr is u'r car? daytime running lights came on all gs's 99 and up. i have a 98 and no running lights, mayb its just my taste but like that with no running lights..
Re: Re: lights?
Re: Re: Re: lights?
Originally posted by brendanlim
Also, some early 99's (like mine) didn't come with DRL's.
Originally posted by rominl
no bulbs will really make the drl look bright white, coz' it's running at so low wattage
for the wheels, it depends on the offset, not just the size
I'm getting a 98, but the TTSUPRA has a 98 too and he has Daytime light.
If you read my orginal post carefully I specifically stated that I do no have daytime running lights but rather the little night lights. Daytime running lights are for newer models which is just the high beams running on 50 percent of their capabilities. Someone correct me if i'm wrong but I think that should be right.
mistake maybe
Originally posted by futuregs
I have 255/35/20 on front...I dont rub unless im in reverse. And I'm lowered in front 1.7
