Correct Offset Gs300 20" Fat Setup
I ordered a set of IForged wheels and I need to give them an offset. I have8.5" in the front and 10" in the rear. I dont plan on gettin any brake upgrades but I do want coilovers in the next 2 months. I wanted a 255/35/20 up front and a 285/30/20 in back. Is this possible with the correct offset. Also would it work with some TIEN CS? Any info would be great. I dont want to be stuck making a newbie mistake.
6 links for you in that thread. I don't think the fat 20" setup will work. There is another post on down about running the 255 up front and it rubs.
https://www.clublexus.com/forums/sho...threadid=85199
20s are already slightly over ~3% taller than stock, even at stock height with no lowering. it would be too tall if you want to run the "fat" set up..and they will rub..no recommended
, from xperiance i know 255 will rub up front and from what i hear 285 rubs in the rear depending on drop. but u could try 245 front and 285 rear , but playing it safe would b 245 front 275 rear...
The guy vince told me I should get +41 in the front and +48 in the rear. What offset did you get Manaray? He said you got big brakes. So the front I should go with a 245/35/20 in the back maybe a 285/30/20.
