HELP!! Can I fit 255/25/20 with 1.25 drop??
Old 05-31-03, 01:01 PM
DR.GS
DR.GS's Avatar
Default HELP!! Can I fit 255/25/20 with 1.25 drop??
Hey Guys
I need your help as I am working on a deal that is based on time so any info ASAP would be so helpful. Can I fit a 255/35/20 with a 1.25 drop or do I have to go with a 245/35/20. Any info would be great....
Thanks
Shamik
Old 05-31-03, 01:47 PM
bravo261
bravo261's Avatar
a 1.25" drop get close to anything really, but you'll have to check those tires sizes. well, the 245 would be better between the two if that's your only choices
Old 05-31-03, 02:38 PM
LexFather
Guest
Posts: n/a
Dang, I guess I'll put this in the wheels and tires sections.
255s will rub up front. Are u talking about the rears?
Old 05-31-03, 07:39 PM
bluelex
bluelex's Avatar
i had 255/35/20 b4 and rub on highway bumps with no drop in the front....go 245 if u can
Old 05-31-03, 09:07 PM
DR.GS
DR.GS's Avatar
Thanks for your help guys. What do you think of going 245/35/20 fronts and 255/35/20 rears??? for a rim that is 20x8.5 +42 offset???
Old 06-01-03, 07:02 AM
bluelex
bluelex's Avatar
not sure if that would b bad.. i think its ok....mayb someone with a better answer will respond..
Mv350
06-09-12 10:35 PM
MaSfLOw
02-18-10 05:49 PM
TIS250
09-18-07 08:52 PM
dle
09-16-07 12:55 AM
DR.GS
06-02-03 08:52 AM
Quick Reply: HELP!! Can I fit 255/25/20 with 1.25 drop??
