Will these fit an AWD RX330?
I have a set of Neeper Shadows that came off my 99 GS300 and I want to know can I put them on a AWD RX330? the size of the rims are 245/40/18...
Re: Will these fit an AWD RX330?
Former Sponsor
Good question...
I can't answer this question definitively. I would not recommend doing this unless you are sure that the load capacity of the wheel is sufficient for the RX330. The bolt pattern and offset are very similar. There are other factors to consider when fitting a wheel. My best answer is that it "probably" will fit on the RX330. You may want to contact the seller or manufacturer of the wheel to get a definitive answer.
I just wonder if anyone would have a clue about it. I ask the dealer and they said that it wouldn't work becuase the gs is a rwd drive and the rx330 is an rwd or fwd...so I guess answers my question.
Registered User
Well, it depends on the width, but most importantly the offset. The reason why FWD/AWD rims don't normally fit RWD cars is because of the higher offsets usually needed for FWD/AWD. You may need to run spacers/longer wheel studs to run higher offset FWD/AWD rims on a RWD car.
