ES300 Lopsided
Old 05-29-03, 11:13 AM
rivera156
rivera156's Avatar
Default ES300 Lopsided
Hello to all LEXOWNAS.
Please assist. I had a flat tire yesterday and after repairing the flat today, and parking, I notice that the car is lopsided from the driver side. The spare was on all night until this morning. I have 18" rims with 225/40/18 tires. Any suggestions?
Old 05-29-03, 01:17 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Air Pressures
Make sure the pressures are the same. I'm guessing you haven't kept up on checking your pressures and the repaired tire is inflated with a higher air pressure then your other tires. On 18 inch wheels I would run no less then 35 psi all the way around and never exceed the maximum inflation pressure listed on the tire sidewall....
http://www.tirerack.com/a.jsp?a=DZ1&...k_pressure.htm
Old 05-29-03, 05:32 PM
rivera156
rivera156's Avatar
Thanks for your quick reply. I carry 36 psi on all four and the tire that was repaired was refilled at 36psi . I will recheck to be 100% sure. The link was helpful. Thanks again
rivera156
33
10-04-23 02:50 AM
edinburger
10-25-09 07:11 PM
IJOCKGS
02-03-05 01:27 AM
HKGS300
04-11-03 12:28 AM
Shinchan
04-21-02 04:34 PM
Quick Reply: ES300 Lopsided
