question on 20" wheels
I have a question for some of you guys sitting on dubz. I have 20" Radius S4 wheels on my 99 GS400. I have already done the Eibach/Bilstein setup, TRD anti-sway bars, and TRD upper and lower brace. Every once in a while, the wheels do rub the wheelwell. Usually on a freeway with dips. Is there a way to modify the wheelwell?
Is it hitting the LINER or the lip of the fender. If it's hitting the lip of the fender, you can roll the lip (but you might have to remove the liner), if it's hitting the LINER, you have to either remove the liner or do a cutout on the liner where it rubs (you should be able to see it)...
The liner is the plastic shell that covers the whole inside of the fender...
