20" GS 400 Rubbing
20" GS 400 Rubbing
This is my first post. I have a 00' GS 400 with H&R springs and 255/35-20" tires. When my suspension packs my tires rub. My offset seems to be o.k. it's just rubbing on the tops of the front wheel wells. Am I running the wrong size tires? Should I go to 19" rims and give myself a little more wheel well? What is the best set up? I Like the 20's but I don't want to worry about going down the freeway with the wife and kid loaded in the car, and having the tires rub when i hit a bump.
Thanks for the replies!!
Hey guys,
I am interested in purchasing 20's but was wondering if 35 profile is too thin? Please let me know because a couple of my friends have had 255/35 and they said their rims bent. Any info would help?
Thanks
Thanks
Originally posted by mtaha
Hey guys,
Thanks
Hey guys,
Thanks
Originally posted by Wheels Boutique
The 255/35/20 should be fine too I have never had a problem you might just need to roll the fender.
Edit: Kinda answered my own question with a quick look on google... 2 decent articles:
http://www.andrews.edu/~johnsonm/howto/rollfender.html
http://www.bmwdiy.info/fender-rolling/index.html
Northern California Regional Officer
I had the same issue w/ front wheel well rub. I simply took a heat gun and pushed up the plastic in the well. I also cut the plastic too, but my drop is more severe than yours....It is not the fender lip that rubs on the GS, it is at the top of the wheel well. Your tire will rub upon driveway entrance w/ tires turned and rolling your fender will help that a bit, but it will NOT help your tire rub when going straight.
See my below thread on what we did.....good luck and stick w/ the 20's!!!
https://www.clublexus.com/forums/sho...&highlight=rub
is250rida
11-01-08 01:29 AM
