17" Tire Sizes (Wider?)
I have tried the search but haven't been able to get an answer to my question. i am going to be replacing my tires. I have the factory 17" chrome rims on my 98 GS400. My question is: Can I put 255's on the rear and 235's on the front? More importantly, is this going to adversely affect the stability/handling of the car?
My though process is that a slighly wider rear tire may give the rear a better look and a wider contact patch. This may be a completely stupid idea; if so just tell me.
I have Michelin Sport A/S tires on stock 17x8 wheels. I have 15mm spacers on the rear with 255/45 tires, and 5 mm spacers on front with 245/45 tires. Absolutely no issues. No rubbing, excellent quiet ride, tires fill out the wheel wells nicely. Probably not as sharp handling as 40 aspect tires, but I prefer the fatter look and comfortable ride. I have about 3,000 miles on them now, and don't see any uneven wear. I am thinking of moving the 15mm spacers to the front and putting 25mm on the rear, but I need to jack the wheels up and check the clearance to be sure the tires will clear the fenders. You can't put 255s on the front without spacers because they will rub on the inside against a wheel fitting. Hope this helps.
EV ftw!!!
So how does the tire wall look on the rear wheels? Is it more curved than straight? What tires do you have on - Z rated?
Are the spacers you have on from H&R? I guess you also must have changed the bolts?
I am considering doing what you did and would appreciate your input.
DEREKC
Wheels, Tires & Brakes Forum
08-05-03 06:16 AM
