Rim weight question
Old 06-23-16, 10:56 AM
MattGS300
MattGS300's Avatar
Default Rim weight question
Kind of an odd question but I searched and couldn't find a reliable answer. So here goes:
I am looking to reduce unsprung weight on my GS for obvious reasons. Right now have stock 6 spoke rims and some god awful generic tires the prior owner put on. Keeping weight in mind, I was looking at as light of a rim as possible which caused me to think. Is it a bad thing to go too light??
The GS s not exactly a featherweight and I saw a set of Enkei rims on tire rack that weighed in at about 18 lbs. Add the new tire with a weight of about 21 lbs, I'm looking at a total of 39 ls per corner. I'm guessing the stock rim is about 25 lbs plus the generic tire at about 23-25 lbs, making the total between 45 - 50 lbs per corner.
Thanks for any input. Let me know if I am totally overthinking this - LOL
Old 06-26-16, 10:16 AM
Mandrake
Mandrake's Avatar
You're thought process is logical but it's more about how the wheel is made than just how light it is. This video might be relevant:
A lot of the Taiwanese and Chinese wheels fall into that category and there are endless pictures of broken knock-off rims.
Schmidt wheels from Germany are also known for having a nearly indestructible radinox lip and had their own interesting way of testing it which became kind of famous in the 90's:
There's debate as to whether there is any truth in the videos however.
So yes, it's completely possible to get a strong and light wheel if it has a good design and construction. One of the biggest factors is the kind of casting they do with the aluminum alloy.
Old 06-30-16, 11:41 AM
MattGS300
MattGS300's Avatar
Thanks for the info, I appreciate it.
The battle is real - low weight rim, good construction, not made in china, look good - lots of things to remember - LOL
Old 06-30-16, 12:08 PM
Mandrake
Mandrake's Avatar
Sometimes a decent compromise is to go with a smaller wheel. You'll find that the weight of the tire doesn't go up much but the weight of the wheel does go down so there's a decent compromise somewhere between 21" and 16".
stevobentz
GX - 1st Gen (2003-2009)
11-06-12 05:21 AM
Brendon
SC- 1st Gen (1992-2000)
16
04-17-10 07:26 PM
e-man
11-11-04 04:00 PM
jinos
06-25-04 09:02 AM
nudderGS400
19
05-05-02 09:36 PM
Quick Reply: Rim weight question
