TPMS light on at 31 psi
Hi so my issue i am having i hope someone can shed some light on why the light comes on. in the early mroning or really late evneing when i go to leave work i work up at 10,000 feet up the canyon and my TPMS light will be on i check the tire presure and all the tires read 31psi wich is more than good enough to keep the light off from what i understand.
then about 20 or 30 miles latter on my drive home the light goes out and its all fine.
anything you can think of thats causing this to happen ?
thanks guys.
thanks guys.
thanks guys.
thanks guys.
is this every day all the time or occasionally?
maybe the battery in one of your sensors is going bad?
this happens occasionally-like once every 6 months in my '10 A5 (at sea level tho) for no apparent reason - all psi's fine - I can manually reset the TPMS inside the car but it's a little scary when I get a warning while going 70mph on a freeway...crappy system too...doesn't state which tire (LF/RF, etc).
