OK..would these fit
Old 04-09-03, 04:13 PM
LS4fun
LS4fun's Avatar
Default OK..would these fit
Hey guys,
I'm wondering if 19 x 8.5 wheels with offset of 36 mm and bolt pattern of 5 x 115 mm can fit on a 98GS without any problems.
I know the bolt pattern is 5 x 114.3...does that slight change make a difference? Offsets ok?
I may have another good deal in the works.
Thanks for the help.
Old 04-09-03, 04:16 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Pretty sure it won't. Unless I'm mistaken...the offsets should be 38-45mm.
Old 04-09-03, 04:26 PM
ATSOU
ATSOU's Avatar
What kind of car has 5x115? Most likely they won't rub.....if they do, u can always custom make your own offsets
Old 04-09-03, 04:38 PM
LS4fun
LS4fun's Avatar
Late model cadillac i think?
Old 04-11-03, 08:40 PM
Sleepyboi
Sleepyboi's Avatar
if the bolt pattern is different i would recommend that you not try them...seems like problems only waitin to happen....my .02 cents tho...not sure...
Old 04-12-03, 03:47 AM
Manaray
Manaray's Avatar
+36 can actually work but if you run a the Fat 19 setup, it will be REALLY close...a standard 19 setup will be ok...(but still too close for my comfort)
As for the 114.3 vs 115...well, you still need to get it drilled out...not something I recommend doing...even though it's only 0.7mm...not as bad as some of the other redrills out there (like 5x120 redrills) but still....the "cone" will be off also...that will force the bolts to bend outward from the center by 0.35mm...dunno about you, but I don't want the bolts that hold the wheels to the car to bend even 0.001mm if I can help it.
Now if you did a "fill and drill", it would be better but it's still a half-*** solution IMO....
Old 04-12-03, 09:19 AM
TTurboPimp
TTurboPimp's Avatar
I would not recommend it, you will be suprised on how many problems .7mm can cause you. It sounds like one of those things that will be a big headache to make fit, time and money.
Old 04-12-03, 10:47 AM
LS4fun
LS4fun's Avatar
Thanks guys! Although the price was incredible on this set, you have convinced me not to do it at this time.
Thanks again.
LIMS407
08-22-11 11:06 AM
Bigwun07
05-13-08 09:41 PM
autoboy
11-16-04 07:51 AM
lexus305
08-22-04 02:11 PM
m0t03
03-02-04 11:10 AM
Quick Reply: OK..would these fit
