SP9000 tires on a GS400?
Old 04-09-03, 06:37 AM
Received 2,127 Likes on 1,379 Posts
Default SP9000 tires on a GS400?
Mods: I know there's wheels/tires forum but I figured maybe I'd get better response here.
Anyone have or has had Dunlop SP9000 tires on their GS400? Comments?
Old 04-09-03, 09:14 AM
LexusGS400
LexusGS400's Avatar
Yes, i had them and returned them after only 2 months. They were making a lot of road noise and had very poor traction. They look nice but overall they just suck and are tooo damn noisy.
Old 04-09-03, 11:12 AM
Thanks! What did you get instead?
Old 04-09-03, 01:41 PM
hlee1169
hlee1169's Avatar
I have 245/40/18 front and 275/35/18 on the rear. I am satisfied with them since this is my second set. I got them because of their reputation in quietness since my rear tires are wider than the standard size. They also wear less than the other performance tires. Of course, I don't think they are as sticky as the other high performance tires, but I value tire noise more than road cornering.
I think I want to try the Bridgestone S3 tires next. My brother has a set on his Celica, and I think they are quiet and have good handling. The only thing is that S3 seems to wear out pretty fast, given a moderate style driving.
Old 04-10-03, 09:16 AM
Well I got the SP9000's. They don't seem quite as quiet to me as the Toyo T1-S's I had, but the Toyo's do wear out very fast. But they do seem VERY smooth.
I just switched from 245/35-19 and 275/30-19 Bridgestone S-03 Pole Positions to taller 245/40-19 and 275/35-19 SP9000's.
My impression of the Bridgestone S-03 Pole Positions is that they're rock hard. They have a reinforced sidewall which makes them ride basically like run flats.
Of course my new SP9000's have a taller sidewall, but it's also more forgiving, so the ride is much more comfortable.
So far so good.
I've learned that tire options for 19's are EXTREMELY limited.
Old 04-10-03, 01:37 PM
hlee1169
hlee1169's Avatar
Can you tell me your impression of the S-3? That's what I want to try next. I think I value noise and comfort more than performance because you do require peak performance 90% of the time.
Old 04-10-03, 01:55 PM
alexulan
alexulan's Avatar
245/40/18 front and 275/35/18 had them on for 15,000 miles.
Lots of road noise.
They had a good ride. Warm up easily.
I would NOT buy them again.
I replaced them with the Khumo's Supra.
Now have different issues:
Tires are square unless they are warmed up for 20 miles.
Less noise but they imposible to balance.
Next set will be something more expensive.
Old 04-10-03, 02:31 PM
I gave my impression in the post above.
Old 04-10-03, 02:44 PM
Originally posted by alexulan
[B]245/40/18 front and 275/35/18 had them on for 15,000 miles.
Lots of road noise.
More expensive? Like what? In 19's and the size I wanted I had only choices, Bridgestone S-03's and Dunlops. If I could have bought them I would have gotten Toyos or Michelines.
I think you've got 18's so maybe you'll have more choices. I highly recommend Toyo T1s. BUT the tread life won't be very long (the tread life 'number' ratings on all performance tires are meaningless I've found).
All tires have trade-offs. Noise, tread life, traction - pick 2!
Old 04-10-03, 08:03 PM
jbbnet
jbbnet's Avatar
I just switched from 245/35-19 and 275/30-19 Bridgestone S-03 Pole Positions to taller 245/40-19 and from 275/30-19 SP9000's.
So far so good.
Bitkahuna,
you been shopping at tirerack? those S0'3 sizes have been on back order for ever it seems...... i'm on the list..... last i heard May 2nd. They been trying to offer me the Dunlop 9000's at special prices..... i'll wait for another set of SO3's.
Old 04-12-03, 11:21 AM
Originally posted by jbbnet
Bitkahuna,
(FYI, I quote my new sizes wrong in the original post - I've edited that now)
No, I didn't buy from tirerack I don't like the idea of buying tires someplace and having them mounted someplace else because if there's ever a problem with them it's a major PITA. Plus, the place I got the SP9000's took the skinnier S-03's as trade-in which was very convenient. I like having a good relationship with quality local shops even if means shelling out a bit more coin.
JBasco20
11-30-10 07:29 PM
emacblane
01-22-07 08:39 PM
gratful
08-19-02 01:24 AM
hoops_24
SC- 1st Gen (1992-2000)
13
06-10-02 01:13 PM
jamecl
05-04-01 01:21 AM
Quick Reply: SP9000 tires on a GS400?
