I need tire size advise on some 20's!
Old 04-10-03, 09:57 AM
TTurboPimp
TTurboPimp's Avatar
Sypher, I will third that. Please post some close up pics, with an angle so we can get a profile of the tire on the rim. Thanks
Old 04-10-03, 10:16 AM
GS4DOUGIE
GS4DOUGIE's Avatar
Default 275/45 Rear
Gents-
I agree with sypher. No rubbing issues or "stretched" look here on mine. I am running 19".
FYI-
D
PS-Is it an offset issue??
Old 04-10-03, 10:59 AM
ATSOU
ATSOU's Avatar
275 is too stretch? I am going to run 255 on my 20x10..........Am I insane???
Old 04-10-03, 11:02 AM
rominl
exclusive matchup
rominl's Avatar
GS4DOUGIE, yours is 275/35/19 on 10" wide rims? can you tell me what rims you got there? the 275/35/19 i saw on another 10" rim was dunlop, it was bad
Old 04-10-03, 11:07 AM
GS4DOUGIE
GS4DOUGIE's Avatar
Default tire wheel info
Rom-
I am runnin with HRE 543 with 19 x 8.5 F 245/35/19 and 19 x 10 R 275/45/19.
D
Old 04-10-03, 11:10 AM
GS4DOUGIE
GS4DOUGIE's Avatar
Default Tires
Sorry forgot tires SO3's
D
Old 04-10-03, 12:56 PM
rominl
exclusive matchup
rominl's Avatar
wha?! you have 275/45/19 in the back?! 275/30/19 is the correct spec, and 275/35/19 in the phat setup. you went 3 spec over spec?!?!
but yeah if you really use 275/45/19, the sidewall won't stretch at all coz' it's so tall. but if you use the spec size 275/30/19 it'd be stretched badly i believe. not sure about 275/35/19 though, but my guess is it would still stretch some.
Old 04-10-03, 01:01 PM
bravo261
bravo261's Avatar
holy cow..you are insane! get some 275 next time!! i'd be careful on hard turns
gs4dougie,
that 275/10" doesn't look anything like mine. yours bubble a bit, which is what i need. that's it...285 for me folks
offsets are kinda hard to understand, but its a number that determines how far or how deep your wheels are relative to the body of your car. you remember those stupid little 14" daytons that stuck out by a mile? its an extreme look if you had a very small offset. have a large offset and you'll have your wheel tucked under your body, so that you can lower your car to the ground and the body won't crush the rim. for GS purposes though, offsets go about 36-50, meaning we're talking differences in millimeters.
Old 04-10-03, 04:28 PM
MrSypher
MrSypher's Avatar
Ok guys just snapped some pics for you... Here goes the rear rim which is 10" wide with a 275/30 Toyo T1-S.....
Old 04-10-03, 04:29 PM
MrSypher
MrSypher's Avatar
MrSypher
MrSypher's Avatar
Old 04-10-03, 04:31 PM
MrSypher
MrSypher's Avatar
Now here you can see that the tire comes out a tiny bit from the rim.....
Old 04-10-03, 04:32 PM
MrSypher
MrSypher's Avatar
What you know about Work Rezax????
Old 04-10-03, 04:33 PM
MrSypher
MrSypher's Avatar
Now here are both tires from under the rear end.. As you can see the tires are pretty verticle...
Old 04-10-03, 04:36 PM
MrSypher
MrSypher's Avatar
Now here is the front tire which also is a Toyo T1-S and is a 245/35....
Quick Reply: I need tire size advise on some 20's!
