explain offset to me
Old 03-29-03, 12:16 PM
Jmai22
Jmai22's Avatar
Default explain offset to me
can someone explain offset to me. and how do i figure out what offset if best for my car. is there a way to measure or is it just testing for best fit?
Old 03-29-03, 09:30 PM
Grimpy
Grimpy's Avatar
Will?
Old 03-29-03, 10:58 PM
GS4Will
GS4Will's Avatar
J,
to avoid incorrect wording, please visit www.tirerack.com as the site has good info on the offsets..
yes, you can test fit, but most Lexus will take offset in the +38 to +50 range
Old 03-29-03, 11:53 PM
Jmai22
Jmai22's Avatar
cool got it. thanks. so if i wanted a nicer lip on the back i would want a lower offset right??
Old 03-30-03, 12:06 AM
GS4Will
GS4Will's Avatar
you would need low or super low disk..and offset closer to +38
Old 03-30-03, 12:12 AM
Jmai22
Jmai22's Avatar
what disk do you speak of? sorry, new to this rim stuff.
Old 03-30-03, 08:02 PM
MrSypher
MrSypher's Avatar
What he means by "low" or "super low" disk is that the space for the caliper.. Like on a super low disk the wheel doesn't pushout that much from the hub not leaving alot of room from the spokes to the caliper.. And on a "High disk" wheel the rim gives alot of space from the spokes to the caliper giving you room to put in some big brakes... I hope this helped....
Old 03-30-03, 08:37 PM
Jmai22
Jmai22's Avatar
totally got it. thanks.
Old 03-31-03, 01:36 AM
Manaray
Manaray's Avatar
Also...
High Disk gives you LESS lip
Low Disk gives you MORE lip
If you're looking to put wheels on your 1st Gen GS, you can do more agressive offsets than the stanard 2nd Gen Offsets...but the exact offset depends on the width of the wheel you want to do.
Old 03-31-03, 10:48 AM
Jmai22
Jmai22's Avatar
Thanks Mike, DTPstyle is running 295 in the rear without any fender rolling and i'm planning to run something similar to that setup. Thanks.
Old 03-31-03, 10:55 AM
Richie
Richie's Avatar
Maybe this can help you.
Old 03-31-03, 11:15 AM
Jmai22
Jmai22's Avatar
that picture is harder to under stand then the tirerack one. thanks though
Old 03-31-03, 11:20 AM
MrSypher
MrSypher's Avatar
lol...
Old 03-31-03, 11:38 AM
Richie
Richie's Avatar
ROFL, no problem dude, just trying to help .
Old 03-31-03, 12:43 PM
bravo261
bravo261's Avatar
a pretty detailed picture though
SWSC400
01-06-06 12:07 AM
newyorksc
Suspension and Brakes
12-16-04 12:19 AM
Blackmarket
04-05-04 05:46 PM
CoachMan
07-13-02 02:19 PM
DaveGS4
22
05-20-02 08:34 PM
Quick Reply: explain offset to me
