Tire Bubbles caused by???
Old 07-10-14, 11:26 AM
KingNasGS4
KingNasGS4's Avatar
Default Tire Bubbles caused by???
What's up guys. I had a set of tires that I used on my old rims.
Tires seemed fine. No bubbles or anything of the sort.
I bent a rim, sold them And decided to keep the tires because they were pretty good.
I stored them in my backyard. They were exposed to the elements.
Fast forward to yesterday. Got my new rims and installed the tires at a tire shop.
Noticed a bubble and immediately checked the tire pressure. It was higher than my gauge could read. (Stops at about 50 psi)
So could that over inflation cause the bubble? I've never seen a bubble before
Or could them being exposed to the elements cause the tire to weaken ???
Thank you all
Old 07-10-14, 12:55 PM
zig@tr
Former Sponsor
zig@tr's Avatar
http://www.tirerack.com/tires/tirete...sp?techid=159&
This should help, click on the link above:
Old 07-10-14, 01:19 PM
KingNasGS4
KingNasGS4's Avatar
I read that prior to making the post. But it doesn't really address my concern of if the elements or even age combined with over inflating can contribute to bulging .
Anyone with personal experiences ?
Old 07-10-14, 11:26 PM
Lextrician
Lextrician's Avatar
under inflation causes bubbles due to impact and separation of the layers of rubber inside the tire as far low pros go. I am not sure about over inflation but that could be an issue but i am leaning to under inflation..
Old 07-14-14, 08:00 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Overinflation can make a tire more susceptible to sidewall damage, aka impact bruises...
Storing them inside, outside, wherever, will not cause this issue - there we would be talking about cracking, etc.
Old 07-14-14, 08:05 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
How did you bend your old rim? Is it possible you also damaged the tire sidewall as well?
How long were they stored?
jamesis350
Chicago Lexus Club
01-11-13 10:27 AM
sam12345
01-10-13 09:09 PM
Banikid
Northeast
12-24-11 03:27 PM
Quick Reply: Tire Bubbles caused by???
