HELP....anyone running 20x9's up front on a lowered 2nd gen.GS?
Old 02-10-03, 10:53 PM
GSTRANCE
GS -Trance
GSTRANCE's Avatar
Default HELP....anyone running 20x9's up front on a lowered 2nd gen.GS?
I need to know if anyone running 9" wide rims on the front of their lowered GS is having any rubbing issues? Also how low is your car? I plan on doing coilovers and drop it down a bit more than Eibachs, and need to know if I am gonna have issues.i will be running a 245/35 tire in the front.Need info asap! TIA
Old 02-11-03, 06:28 AM
dagr8tsthustla
dagr8tsthustla's Avatar
Hey trance,
I don't have my car lowered but I do have 245/35 on my front 8.5 and I rub when I turn the wheel and reverse....as for MrSypher he has the same problem and his is lowered w/coilovers....and you know he's low!!! I think you might have some problems.....but there maybe a solution to getting away w/it...check out the link below of Synergy's car...hope this helps....and contact MrSypher about his rims...maybe he can give some better input. Hope this helps!!!https://www.clublexus.com/forums/sho...5&pagenumber=2
Danny
Old 02-11-03, 09:29 AM
TTurboPimp
TTurboPimp's Avatar
Mine is dropped pretty low(no gap at all), im running 9" wide rims with 255 tires. I get a little bit of rub on the plastic liner when turning extremely sharp, other than that its all good. If I had 245's on there I probably wouldnt rub at all. I did have to do some trimming of the liner and one metal tab on the fender well to get it to this point, but nothing major!
Old 02-11-03, 10:08 AM
Kajukenbo
Kajukenbo's Avatar
you might want to try gsintenisve....I know he has 9" set up in front.
Old 02-11-03, 06:50 PM
PAULGS430
PAULGS430's Avatar
Question strange
I have Tein/flex w 1.75 drop. I'm running 245 frnt. 275 rear w/ no rubbing from turn to turn. OK on speed bumps too if ya go slow.
1 finger gap. hhhmmm.
Paul
Colly3
Build Threads
08-22-16 11:06 PM
JBLUR
05-04-14 12:45 PM
Orozco27
01-19-14 10:43 PM
350police
06-30-10 10:54 AM
sjlex
01-08-09 11:27 PM
Quick Reply: HELP....anyone running 20x9's up front on a lowered 2nd gen.GS?
