DIY Nitrogen for Tires
Old 03-13-14, 04:44 PM
GRPFAN
GRPFAN's Avatar
Default DIY Nitrogen for Tires
Anyone know if the nitrogen used in our Lexus tires can be purchased in container/bottle at a auto supply store for us to fill our tires at home?
Old 03-13-14, 11:42 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Technically, yes, but there is no simple way... It includes going to your local compressed gas facility and paying rental on a nitrogen tank and the fills for it....
Not worth it, not one bit....
Nitrogen filled tires for a fee have to be one of the biggest scams ever... All of the supposed benefits, and not a one comes to fruition... If you have a race car that depends on pinpoint pressures throughout a race, maybe... But that doesn't apply to 99.9 percent of us here...
Old 03-14-14, 05:39 AM
GRPFAN
GRPFAN's Avatar
I also understand nitrogen slows down oxidation around the seal/bead area of alloy aluminum rims
as they get older to prevent air leakage.
I own a Lexus '00 RX300 without using nitrogen, and after 8-9 years, the psi was losing pressure
every week around the tire seal.
Old 03-14-14, 06:42 AM
mitsuguy
mitsuguy's Avatar
Unfortuately, that happens regardless of nitrogen filled or not...
Every supposed benefit, I haven't seen actually work in practice.
Partially because in a conventional setting, it is almost impossible to add 100% nitrogen...
Old 03-16-14, 12:24 PM
GSteg
GSteg's Avatar
Regular air contains almost 80% nitrogen. That extra 20% won't do a darn thing.
Old 03-16-14, 12:28 PM
Joeb427
Joeb427's Avatar
Does air pressure not drop as fast with nitrogen?
davvv
01-21-10 05:07 PM
Spacepig
12-19-09 12:52 AM
radicalrev
04-02-09 11:07 AM
Quick Reply: DIY Nitrogen for Tires
