Need help with tire size on IS 250 AWD !
Old 01-05-14, 11:51 AM
NickawdIs
NickawdIs's Avatar
Default Need help with tire size on IS 250 AWD !
I no there is a thread but can't seem to find what I'm looking for so all 4 rims are the same 18"x9.5" +35 . I was thinking since its non staggered i can do 245-35-18 all around ?
Old 01-05-14, 12:46 PM
Bushum
Bushum's Avatar
For reference I ran 245/40/18 on OEM G Spider wheels. You'll have to look up offset as I don't know it. The installer said 8.5" wheels would have rubbed on the front so I used 8" on all four.
Old 01-05-14, 02:27 PM
NickawdIs
NickawdIs's Avatar
Originally Posted by bushum
for reference i ran 245/40/18 on oem g spider wheels. You'll have to look up offset as i don't know it. The installer said 8.5" wheels would have rubbed on the front so i used 8" on all four.
+35 offset
Old 01-05-14, 07:02 PM
Bushum
Bushum's Avatar
If the offset is the same I would say they won't fit. I never actually tried 8.5" but the 8" were very close to the control arm with a 245 tire. Why are you looking at such wide wheels? My Corvette has 9.5" on the front with 275mm tires.
Old 01-05-14, 08:27 PM
NickawdIs
NickawdIs's Avatar
I see awd people running 19 by 9.5 even 20 by 9.5 they have no problem !
Old 01-05-14, 08:30 PM
Largefarva
Largefarva's Avatar
Not sure about rim fitment, but the best way to tell is a trial fit (obviously). The tire size is a bit narrow though, they will look pretty stretched on a 9.5" rim, not to mention the shop will probably need a blaster to get them to seat.
Old 01-05-14, 08:37 PM
NickawdIs
NickawdIs's Avatar
I work at a body shop ill put them there. What tire size should i get ?
Old 01-05-14, 08:41 PM
NickawdIs
NickawdIs's Avatar
Other car forums are saying 275/35ZR18
Old 01-05-14, 09:19 PM
NickawdIs
NickawdIs's Avatar
Hey i need help i have is250 awd with 18"x9.5" +35 all around , whats the best tire setup ?
Old 01-05-14, 09:39 PM
NickawdIs
NickawdIs's Avatar
front 235-35-18 / rear 265-35-18 ?
Old 01-06-14, 12:27 PM
cxc511
cxc511's Avatar
With AWD, I would be careful to keep the height of the front and rear tires the same. Not sure what the optimal staggered set up would be for your car, but the rear tires you mention are 0.8" taller than the front. 235/40/18 front would be nearly the same height as a 265/35/18.
Old 01-06-14, 12:40 PM
NickawdIs
NickawdIs's Avatar
I was thinking since all 4 wheels are 18 by 9.5 i could run the same size tire ?
Old 01-06-14, 01:31 PM
NickawdIs
NickawdIs's Avatar
My friend is running 225-40-18 all around so ima do that !
Old 01-06-14, 03:11 PM
cxc511
cxc511's Avatar
If I had same size wheels on all four corners then I would go with the same size tires. You can then rotate your tires and get better wear out of them. Just wanted to point out the need to be careful when putting a different size tire on the front and rear on an AWD, as it can hurt the drivetrain with the front and rear tires rotating at different speeds. Good luck.
Old 01-06-14, 04:47 PM
Largefarva
Largefarva's Avatar
On a 9.5" rim-I highly doubt that will work. And yes, all four need to be exactly the same height, staggered tires will work but they cannot all be 35-series if they're different widths. I'd go with a 265 or 275/35, but so you're aware-that's a pretty wide tire for such a small car, you may notice it following ruts in the road, or having heavier steering than you're used to. Personally I think those rims are way too wide.
Quick Reply: Need help with tire size on IS 250 AWD !
