Will lower profile tires on stock 18x8.5 wheels cause any issues? - Club Lexus Forums
Thread Tools Search this Thread
Old 12-25-13, 01:39 AM   #1
sichigo
sichigo's Avatar
Default Will lower profile tires on stock 18x8.5 wheels cause any issues?
09 2IS owner here, I'm currently tire shopping. Since I'm not too fond of the mismatched OEM tires look (225/40/18F with 255/40/18R) too bloated in the rear. I'm thinking about doing the BMW/Benz tires fitment. Keeping 225/40/18 front but lowering profile to 255/35/18 in the rear.Will this set up cause any issues? I would like a more flat sidewall if possible. Thanks.
sichigo is offline   Reply With Quote
Old 12-25-13, 08:22 AM   #2
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
It will cause issues. All of your factory wheel speed sensors and the ABS / Traction computer are calibrated with a difference in tire diameter front to rear...
Also, the shorter tire will look silly as the wheel well gap will increase, so although to you the tire may look better, the fender gap will not...
mitsuguy is offline   Reply With Quote
Old 12-29-13, 06:54 AM   #3
boxbrownie
I do not understand the problem, as going from a 40 to 35 profile will make no difference to the "bloated" width as your keeping the 255, and the tyre wall depth decrease will be minimal (12mm decrease which is about 10% of the sidewall height) if at all noticable.
If you really do not like the "bloated" wide rear tyres fit the same as the fronts, but be aware that handling will be severly compromised and insurance will most likely be void also.
boxbrownie is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Tire diameter increase jennypenny IS - 3rd Gen (2014-present) 17 07-10-14 07:34 PM
Quick question: Anybody run 255/35/18's in the rear? S00Pah5L IS - 2nd Gen (2006-2013) 4 03-18-14 04:31 PM
Will this Wheel/Tire size work? CT200h orangedrin The Tire Rack's Tires, Wheels & Brakes Forum 2 02-26-14 11:55 PM
2014 is350 Vairox IS - 3rd Gen (2014-present) 6 01-10-14 11:41 AM
higher profile tires 68vert IS - 2nd Gen (2006-2013) 7 04-27-13 10:04 PM
Tags
18x85, low, profile, rim, rims, tires, tyres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
