Sidewall bubbles.
Old 10-12-13, 12:57 PM
3gs350awd
3gs350awd's Avatar
Default Sidewall bubbles.
Happened to my vossen. 20x9 245\30\r20
tire is nitto invo used less that 5 month. bought them new.
was wondering if this has happened to u before. and whats the likely cause of it.
Old 10-12-13, 02:44 PM
msgs350
msgs350's Avatar
I've had that happen with back in the day....forgot what tires though. Do you have tire warranty?
Old 10-12-13, 06:46 PM
chinewalk
chinewalk's Avatar
you have a sidewall impact break. Likely from hitting a bump or pothole on the street. It is unsafe and the tire needs to be replaced. This is why im downsizing to 19" wheels
Old 10-12-13, 09:34 PM
XxGoKoUxX
XxGoKoUxX's Avatar
chinewalk hit it right on the money. The threads inside your tire keeping it in place has broken. You have either hit a pothole, a harsh bump, or you let the tires run flat. It happens (in my case, the dealer let the tire run flat and rode on it, causing the same issue you claimed).
Extremely unsafe, so get it fixed asap.
Old 10-13-13, 01:28 AM
aLexGS350
aLexGS350's Avatar
definitely get its fixed. Happen to me and I didn't think much of it. One day as i was exiting to my house the tire popped out of no where. Likely i was only about a mile away from home and in the neighbor so i was able to drive very slow.
Old 10-13-13, 12:29 PM
3gs350awd
3gs350awd's Avatar
i did experience the same thing you guys have mentioned above. im back on stock rims now. emailing the tire place about warranty. i have bought it a little over a year so i hope its still covered.
driving daily its impossible to avoid all potholes and harsh bumps.
might just downsiize to 19s. oh god im gona miss the look of my 20s
Old 10-13-13, 06:10 PM
bklynjoker
bklynjoker's Avatar
Happen to me with nitto555. hit a pothole- brand new tire too. S**** happens
[IMG][/IMG]
Old 10-13-13, 06:15 PM
bklynjoker
bklynjoker's Avatar
http://<a href="http://postimg.org/i...[/img]</a>
Old 10-13-13, 06:59 PM
XxGoKoUxX
XxGoKoUxX's Avatar
I'm fortunate that I know and predict all potholes bumps and stuff on the road, so I avoid'em as I drive to school everyday.
Old 10-14-13, 03:02 AM
IXI187IXI
IXI187IXI's Avatar
yea it sucks, happened to before with Falken 452's. Look on the bright side though, the pothole could have been worse and bent a rim.
Old 10-14-13, 01:20 PM
PHML
Master Thread Closer!!
PHML's Avatar
need to find tires with stronger sidewalls.
Old 10-14-13, 01:32 PM
ohiois350
ohiois350's Avatar
I have the same size and tire brand, and I hit the pothole few times and my wheel's got bent, but no bubbles like your, I think Nitto would replace under warranty.
Old 10-16-13, 07:43 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Air pressure and pure luck play into this.
I've seen wheels completely destroyed, with no damage done to the tire.
I've seen tires with impact breaks and no damage to the wheel...
Unfortunately, there is no such thing as a tire with a stronger sidewall, they are all susceptible to this.
Old 10-17-13, 05:12 AM
zig@tr
Former Sponsor
zig@tr's Avatar
Nice article on sidewall bubbles:
http://www.tirerack.com/tires/tirete...&affiliate=DZ1
Aeromotive
04-13-15 03:05 PM
1993ES300x
06-10-08 10:31 AM
phillies
04-19-08 09:52 AM
Franknyc30
07-03-07 10:15 PM
the lndr
17
02-02-06 03:53 PM
Quick Reply: Sidewall bubbles.
