tires suggestions for stock 17s GS
anyone out there know about some good all season tires? should i get the bridgestone potenza? 480.00 is that worth it for all 4? never in snow. thanx!
dunlop sp5000, yokos avs es100, b-stone re730
www.tirerack.com has tons of feedback from users..good luck
thanx
i will check them out. am i mistaken or have i heard bad things about the tires the car comes with stock???? anyways thanx for pointing me in the right direction!
I have Toyo Proxes T1S's on stock 17's and love them. Work great in the rain - never done ice and snow. After doing quite a few searches here, I couldn't find anyone who was dissatisfied with them.
I have Yoko AVS520's on another car and they are LOUD. I hear the ES100's are supposed to be quieter tho.
thanx
Originally posted by GS4Will
stock tyres, b-stone re030 are not up to par...expensive too...as well as short life expectancy...
many other good chocies out there
If you're just going to drive in dry and wet weather (i.e. rain) and not snow, then from what I hear the Potenza S-03s are the best. If you're looking for a good deal on all season tires, the Pirelli P7000 SuperSport are $98 each on TireRack. I had a set of those on my 3000GT and they were pretty good. Another supposedly good tire for the price is the Sumitomo HTR+. They are only $104 each and compared well against the Michelin Pilot Sport A/S and Pirelli P7000 SuperSport in this test that TireRack conducted on an IS300 with 17" wheels.
http://www.tirerack.com/tires/tests/...reModel=HTR%2B
If money is not an issue and you want a true all season tire then I'd get the Michelin Pilot Sport A/S. I had the Michelin Pilot XGT Z4 (the predecessor to the Pilot Sport A/S) on the stock 17"s that I had on my last GS and I loved them.
i got great treadlife out of the dunlop 6000's. currently using all season tire (MN). bfg g-force kdws. doesn't look as good on the 17's as the dunlops, but great all season tire.
tirerack tests
I like reading those tirerack tests -- but I wish they would wear down the tires for ~12k-15k miles THEN do the tests. I always wonder how the cheaper tires perform near the end.
good info.
One other thing I forgot to mention. All season tires like the Michelin, Pirelli and Sumitomo will last much longer than the Bridgestone S-03's. All season tires are usually made from a harder rubber so they last longer. Since the Bridgestone S-03's are a performance tire, they will be made from a softer rubber so they will stick to the road better for better handling but this softer rubber will wear out faster.
You'll notice the difference in UTQG ratings (treadwear rating) between a performance tire and all season tire from the same manufacturer. You cannot compare UTQG ratings from one manufacturer to another because each manufacturer sets their own baseline rating. Here is an explanation of UTQG ratings.
http://www.tirerack.com/tires/tiretech/general/utqg.htm
Just to give you an idea, the Bridgestone S-O3's have a UTQG treadwear rating of 220 and the Bridgestone RE950's have a rating of 400 which means that the RE950's will last almost twice as long as the S-03's.
Alexus-Kia
Wheels, Tires & Brakes Forum
25
01-29-05 02:11 PM
FutureGSorIS
Wheels and Tires Classifieds
07-07-04 09:58 AM
