Supra NA rims won't fit?
Old 12-25-02, 06:01 AM
Grimpy
Grimpy's Avatar
Default Supra NA rims won't fit?
Hello, I recently got Supra NA rims, the 16" ones. I could not get them to fit over the center hub. My hub seems to have a piece on them that looks like they can be removed. Once removed, I am sure the rims will fit...
Would it be safe if I removed that piece?
Old 12-25-02, 02:52 PM
pcmw
pcmw's Avatar
SC4oo,
You probably have old centering rings from your other wheels stuck on the hub.
The Hub centers are just the black piece and should measure 2" approx. Only other thing on the hub center is the brake rotor.
MW
Old 12-25-02, 05:09 PM
Grimpy
Grimpy's Avatar
If they were centering rings... Would it be ok to popped them off? Also If I need to put them back on, would it be ok or will it wobble after?
Old 12-25-02, 05:15 PM
pcmw
pcmw's Avatar
SC4oo
Centering rings are names that because they center your wheels onto the hub. Some wheel makers prefer to bore out the wheel centers to a standard size and use different centering rings to make their wheels hubcentric. These rings are interchangeable with other sizes to fit several vehicles. They are suppose to be ON YOUR WHEELS not the hubs. They do tend to stick on occasion but you should be able to slide them off and insert them back into your aftermarket wheels. For obvious reasons, FACTORY OEM wheels DO NOT have centering rings as the wheels are built only for one vehicle.
MW
Old 12-26-02, 01:10 AM
Grimpy
Grimpy's Avatar
Thanks bro,
I'll try to pry the center rings off. Just wanted to make sure if I took them off and wanted to put them back on, it would not wobble.
Darrin
Old 12-26-02, 12:39 PM
pcmw
pcmw's Avatar
SC4oo,
Before you sell them. Take a picture of the hubrings and the backside of your old wheels.
Maybe someone can give you a hand.
MW
yeSaC300
SC- 1st Gen (1992-2000)
12
07-15-13 04:53 PM
boostinsc
20
05-24-10 06:06 AM
9520G
01-15-08 12:52 PM
dsdfan
14
02-25-07 11:45 AM
VJ RC51
03-01-06 10:17 AM
Quick Reply: Supra NA rims won't fit?
