New 19 inch rims with different offset from OEM. DO I need alignment?
Old 04-02-13, 10:13 AM
Rexus300
Rexus300's Avatar
Default New 19 inch rims with different offset from OEM. DO I need alignment?
I got 19 inch forged rims for my 2013 GS F-sport and the offset is less and the wheels sit out more from the center. The tire size are the same. Do I need a re-alignment with the different offset? I feel my car wanders a bit at higher speed with and without crosswind then before.
Old 04-02-13, 01:11 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Alignment won't change because of the different tire and wheel sizes. Camber and caster are measured in degrees, toe can be measured both ways, but most measure in degrees as well.
That being said, might not be a bad idea to have the alignment at least checked though...
Old 04-02-13, 03:40 PM
Rexus300
Rexus300's Avatar
Thanks Mitsuguy.
Nice to get an honest answer from someone. I will just get the alignment checked out to be sure since it was a rough winter with my winter sets and the potholes here in Michigan.
Old 04-02-13, 05:07 PM
LexRuger
LexRuger's Avatar
I'm on my fifth car with aftermarket wheels and I've never got an alignment for them and no one has ever recommended that I get one for new wheels. you might have needed it before but the new wheels have made it more noticeable.
Old 04-02-13, 05:13 PM
Rexus300
Rexus300's Avatar
I agree with your assessment. The bad roads must of put alignment out of spec. The 18 inch winter set and the thicker winter tires made the car track better but less sensitive to the road crowns, etc while the wider and larger 19 inch summer set makes the out of alignment more noticeable.
mikez
Suspension and Brakes
04-24-08 10:00 AM
minla007
08-07-06 09:18 AM
ktang235
02-13-06 06:25 AM
beaterKU
10-12-05 01:12 PM
virtualinsanity
06-10-02 09:37 AM
Quick Reply: New 19 inch rims with different offset from OEM. DO I need alignment?
