DIY Brake pad change. Something wrong i did? Pic include
Old 03-25-13, 09:23 PM
Skggyy
Skggyy's Avatar
Default DIY Brake pad change. Something wrong i did? Pic include
Today, i am trying to do rear brake pad change on my 2000 ES300. I have done this before on my camry and GS430. So, i am pretty confident i can handle it. However, after i push brake cylinder priston all the way back. i find out the rubber boost wrap the piston is fill up by the air. and can't push back. And i still put them back on. But when i do other side. the cylinder booster and rubber boost looks normal as how it supposed to. My questions is: will this damage my brake cylinder. how do i fix this problem? Picture shows as below. The first one is passenger side with problem. the second picture is the normal position. Thanks.
Attached Thumbnails DIY Brake pad change. Something wrong i did? Pic include-brake-1.jpg   DIY Brake pad change. Something wrong i did? Pic include-brake-2.jpg
Old 03-27-13, 08:26 PM
k7q
k7q's Avatar
take out the caliper and try to move the boot around. they should retract back into place like the second pic
thaeleelyr
RX - 1st Gen (1999-2003)
04-23-14 04:41 PM
Skggyy
03-26-13 12:42 PM
SEBASS
15
06-10-11 09:22 PM
acc
02-07-08 12:08 AM
p1fcl01
18
03-07-07 12:18 PM
Quick Reply: DIY Brake pad change. Something wrong i did? Pic include
