Is offset just offset regardless of rim size??
Old 12-13-12, 04:07 PM
celm
celm's Avatar
Default Is offset just offset regardless of rim size??
for example take a 18x8.5 rim with a 40 offset, replace with a 20x8.5 with 40 offset. the clearence between the rim and caliper should be the same with 18 and the 20 correct?
Old 12-13-12, 11:50 PM
rominl
exclusive matchup
rominl's Avatar
incorrect, rim widths and offsets go hand in hand, offset is meaningless without widths.
but to your other question, offsets and caliper (brake) clearance doesn't have too much to do with each other either. it's the spoke design (or disk type) that matters most
Old 12-14-12, 03:41 PM
zig@tr
Former Sponsor
zig@tr's Avatar
If both wheels are 8.5" wide and both have a 40mm offset then technically they would both mount up in the same location under the vehicle. But just like rominl said, you could have a 20X8.5 w/40mm offset and 18X8.5 w/ 40mm offset and one could hit the caliper and one may not. The fitment depends on spoke design as well as offset, if the spokes don't protrude outward enough the wheels may not work on your car.
Wheel Offset Link
stlgrym3
04-05-17 10:33 AM
tures
06-02-13 03:47 PM
yusef
02-11-08 07:15 PM
Jasono31
06-27-01 10:23 AM
Quick Reply: Is offset just offset regardless of rim size??
