06gs awd question
Old 09-04-12, 01:20 PM
GSMoving
GSMoving's Avatar
Default 06gs awd question
Can I run 245 40 18s on the front and 255 40 18s on the rear without any issues? The key being 245 and 255 front to back. The car is a 06 GS300 AWD.
Old 09-04-12, 07:08 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
only if you don't mind destroying your driveline in the process... the car was designed to have all 4 tires turn at the same speed all the time - if you constantly have different diameter tires turning different speeds, you will damage the center differential and/or other related pieces that are usually pretty pricey...
it isn't even recommended to replace two tires at a time unless you are replacing with identical model with less than 2-4/32" tread depth difference from the existing...
Old 09-06-12, 06:37 AM
zig@tr
Former Sponsor
zig@tr's Avatar
mitsuguy is absolutely right, if this was an RWD there would be now problem but on the AWD all 4 tires have to be the same height. I know they're pretty close but that 0.3" difference multiplied over thousands of miles could damage the drivetrain. In my opinion the esthetics are not worth the damage to the vehicle.
Old 09-07-12, 05:34 AM
GSMoving
GSMoving's Avatar
Thanks, ordred two new to match.
310rc
RC - 1st Gen (2015-present)
06-28-19 08:08 AM
Tcagle
05-29-18 04:18 PM
Knucklebus
03-27-18 12:08 PM
shivam
03-11-14 08:46 AM
GSMoving
09-07-12 05:39 AM
Quick Reply: 06gs awd question
