wheel fitment check -
18X8.5 in the front with a 40 offset
18X10.0 in the rear with a 38 offset
BOLT PATTERN: 5X114.3
will the rears rub?
i was thinking like 275 tires....
will the rears rub?
Originally posted by TerryTCL
so, the 38 offset in the rear will rub?
hm...
hm...
TinyGS has 19x10 +41 with 285/30 tire and had to cut the fender with a mild lowering.
Personally, I think the PERFECT offset on the GS is +39 front and +41 rear with 8.5f and 9.5r.
If you have a great deal on the rims, you might be able to have a machine shop mill off a few mm of the pad. Put a 275 tire (too small) and you might be ok.
