Staggered tire size question
Old 07-14-12, 11:52 AM
BlueIS88
BlueIS88's Avatar
Default Staggered tire size question
Currently running 17x7's up front and 17x 7 1/2's in the rear . On an 02 is300. All oem suspension . Current tire size is 225/45 up front and 235/45 rear. The car has a slight rake to it the rears are about half an in taller then the front . Dont mind changing all 4 tires , anyone know what tire sizes will level the car out ?
Old 07-15-12, 12:39 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Is your IS300 a Sportcross Wagon?
If so, your OE tire sizes are 215/45-17 front, 225/45-17 rear. This is about the same difference from front to rear as your car currently has. If your car is a Sportcross, it would be recommended you keep that difference from front to rear - the car was designed with that in mind, probably due to a little more rear weight distribution...
You could install the same size tire on all 4 wheels, going to a 235/45-17 on the front, although 235/45-17 is a little wide for that wheel. That being said, I run 235/45-17 all around on the standard IS300 wheels which are 7" all around...
Old 07-15-12, 06:50 PM
BlueIS88
BlueIS88's Avatar
Yes rims are off of a sportcross. I dont have one . Theyre on a sedan . I was thinking about running 225/45 all around . Wondering if the stretch from the extra 1/2 of rim would affect height . Assuming it wouldnt be enough to make a differnce
Old 07-15-12, 09:30 PM
mitsuguy
mitsuguy's Avatar
Wish you were closer, I'd love to trade wheels, even plus a little cash...
wheel width has no effect on tire diameter whatsoever...
Nadim
06-03-17 10:05 PM
RUCKER
04-20-15 01:25 AM
Skelinton
12-26-12 08:19 PM
fc3s
02-10-12 08:43 PM
sa_dude1
01-31-07 06:55 PM
Quick Reply: Staggered tire size question
