Stretched tire pressure
Hello all, I've searched but I just can't find a answer. Unless I'm just blind, no offense to the blind. But I plan on running Achilles atr sport 225/35-19 on 9" wide and 235/35-19 on 10" wide. What would you recomend as tire pressure? I know it's a light stretch compared to others, or atleast I think. Thanks in advance
dont know the LI of said tire but usually stretching involves running a tire that will be overloaded due to its LI being under OEM LI. (LI = Load index)
That being said you would normally run it higher than OEM since more PSI in tire = capacity to carry the weight is better.
Its not a recommendation just pointing out some tech facts. hope thats helpful.
Don't know if what info I gave is right. Also this set up is going on a 98 ls400. Thanks again
tfz_hebe89
10-24-08 03:44 AM
achilles, atr, chicago, lexus, ls400, maintenance, pressure, sport, streatched, streching, stretch, stretched, stretching, tire, tires
