Spacer fitting on Eurolines
Old 02-04-12, 04:04 PM
DixonPai
DixonPai's Avatar
Default Spacer fitting on Eurolines
We are putting Euroline on Ichiba 25mm spacers, but the spacer studs is not fitting into the lug holes, its like a slight centimeter off, anyone else have or had this problem?
Old 02-04-12, 10:19 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
pics? perhaps you have the wrong bolt pattern spacer?
Old 02-05-12, 12:24 AM
DixonPai
DixonPai's Avatar
ill see if I can get pics tomorrow, and no I am sure I got the right ones, cause I used my spacer on my current set of wheels, its like the bolt is to thick for the eurolines
Old 02-05-12, 06:35 AM
mitsuguy
mitsuguy's Avatar
ohhh... so the wheel studs on the spacers physically won't fit through the bolt holes on the wheels?
probably the wrong size studs... your aftermarket wheels probably require 12mm or 1/2" studs, and the studs on the spacers are most likely larger, like 9/16" or 14mm...
might be able to replace the studs in the spacers, but should probably just order a different spacer with the proper studs... (if that is the problem)
PolishDude
04-25-16 02:27 PM
CleanCL
Wheels and Tires Classifieds
10-13-10 11:00 PM
telmz1
12-29-09 03:17 PM
supralative
SC- 1st Gen (1992-2000)
13
03-13-09 01:55 PM
Quick Reply: Spacer fitting on Eurolines
