what do u guys think...
Old 10-16-02, 01:36 PM
aldo23
aldo23's Avatar
Default what do u guys think...
[IMG]A:\MVC-029S.JPG[/IMG]
Old 10-16-02, 01:41 PM
aldo23
aldo23's Avatar
I've asked many people in this forum on what can i do w/ my old rims(bersaglio's or for u americans Lowenharts) 19/8/48 offset.
So I decide to do a little bit of labor and this is what I got. To me they look nice and they fit good, mind u I have to drop the car an inch, and increase my tire so i wont feel everything. But, am i going to run to into any problems b/c of the offset or width????
Logicaly the rims i'm replacing are stock, and they're all the same size and diameter, so how could increasing the rim and tire cause a problem(need advice)...
Do u guys like the look?
Old 10-16-02, 01:45 PM
aldo23
aldo23's Avatar
Default My previous ride, u guys have to admit, it was a hot ride
[IMG]A:\MVC-003S.JPG[/IMG]
Old 10-16-02, 01:50 PM
aldo23
aldo23's Avatar
Default significant gap, i guess i need springs..
[IMG]A:\MVC-030S.JPG[/IMG]
Old 10-16-02, 02:23 PM
GS4Will
GS4Will's Avatar
looks fine..drop it and it would look even better
Old 10-16-02, 05:28 PM
aldo23
aldo23's Avatar
I was just told a 48offset will probably, well more than likely damage my suspension, can any1 here agree or disagree on that???????????????????
Old 10-16-02, 06:08 PM
Grimpy
Grimpy's Avatar
=) Looks good just get rid of that acura cap and you will be fine!
Old 10-16-02, 06:39 PM
Wheel Experts
Wheel Experts's Avatar
What I told you earlier was that with a 19x8 +48 and a 245/40/19 (aka the "FAT" setup), when the car is lowered it may touch the inner suspension upon rebound/compression...but that was just my opinion.
The TL looks pretty nice there, though
Old 10-16-02, 10:17 PM
aldo23
aldo23's Avatar
Wheel Experts, dont get me wrong, due to your commentary, i have completly changed my mind on keeping the rims. I think i may just go stock 17"s and call it a night. Unless some1 out there has a similar set-up and can gurantee, or atleast be sure that I will not run into any problems w/ suspension...
there has to be some1 that has a 48offset..
Old 10-16-02, 10:31 PM
Wheel Experts
Actually Gene used to have a 19x9 +48 on his SC430, and it worked fine. IT MIGHT JUST WORK!!!!
The only way to tell, is to get a 245/40/19 or a 245/35/19 on a test it out.
Old 10-17-02, 05:29 AM
Manaray
Manaray's Avatar
You could also just buy a high quality 5mm spacer...
Aa 245/40-19 on a 8" setup is not "ideal"...the "Fat" setup on a 8.5" wheel looks good but to some people, it looks a little "bulky"...on a 8", it's going to look bulkier...too bad no one makes a 235/40-19...
As for offset, you should be ok...compared to a 19x8.5 +41 that we did on the Weds (with a 245/40-19 setup), the 19x8 +48 will only be 1mm closer to the shock...it should fit fine...but like Peter said, there is no way to be 100% until you try it...
Old 10-17-02, 01:17 PM
Lexozz
Lexozz's Avatar
Honestly those rims don't look good on the GS, it gives the car a weak appearance, they look way better on the Acura. Its just my honest opinion!
lexboi250
05-01-08 10:19 AM
ISbb
09-14-07 09:17 AM
F4Luder
10-10-04 07:49 PM
Vegassc400
04-12-03 10:44 AM
gwu128
04-07-02 09:26 AM
Quick Reply: what do u guys think...
