Tire PSI for 19"
The tire sidewall should say what the max psi it can handle. Also keep it mind that air pressure expands in warm tires so if the tires are still cold then you have to compensate for that fact (like go 35psi on cold tires that are rated 40 psi max).
Maintenance Moderator
Actually, there is some incorrect information in this thread...
The sidewall of the tire has the maximum cold air pressure listed on the side. Generally between 35 and 51 psi for most passenger car tires. Passenger car tires carry their maximum load at either 35, 36 or 41 psi, depending on the tire's load designation. You may feel free to inflate your tires to the maximum pressure when cold. When hot, you can safely add 3 psi to this.
Now, here is the deal - the higher the air pressure, the GREATER chance you have of an impact damaging the tire. The higher air pressure may offer a little impact protection to the wheel, but not by a whole lot.
Anything over the air pressure at which the tire carries the maximum load is just for adjusting the way the tire handles and how much it rolls over under hard cornering...
With years of personal experience in this, somewhere between 35 and 40 is the sweet spot for most low profile tires...
Mostly, running over 40 psi on these cars does nothing but kill ride quality. If you were tracking the car you might run higher, but you would only be able to tell this by chalking the tires, getting them up to temp, and running a few laps.
I run about 38 on my GS, and this is only to attempt to 'crown' the tire a little to combat a bit of negative camber. It doesn't really help much.
