Need help with tire size and other
Old 08-06-11, 10:14 PM
trickz
trickz's Avatar
Default Need help with tire size and other
please delete found my solution
Old 08-07-11, 12:10 PM
SChema
SChema's Avatar
Aspect ratios of 30 and 35 are all relative to section width. Meaty tires and decent stretch are two different things that usually don't go together. Wheels specs will help a lot when sourcing tires.
Old 08-07-11, 02:26 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
those wheels probably aren't going to work on your car, especially with spacers...
BMW's typically run pretty low offsets, in the 20-25 mm range, then adding a spacer puts you in the 0'ish range, where most wheels for any Lexus are in the 35-45 mm range...
you aren't going to get meaty tires and stretched...
which 745Li wheels are we talking about?
Old 08-07-11, 09:47 PM
trickz
trickz's Avatar
the concave multi spoke, but i seen these rims on other club members cars and they fit no problem. my fenders are slightly pulled and they are shaved.
Old 08-08-11, 07:51 AM
zig@tr
Former Sponsor
zig@tr's Avatar
I'm with MITSUGUY on this one, seems like this is not the best fit. Also, we can't recommend tires if we don't know anything about the vehicle. Perhaps you could provide the year & model of your Lexus and even the year & model of the BMW the wheels the wheels came from then we can better make suggestions.
Old 08-08-11, 08:06 AM
mitsuguy
mitsuguy's Avatar
just had a chance to look and I see about a dozen different wheel setups that could have came on a 745... they are almost all multispoke... I see everything from 18x8 to 21x10...
as Zig said, more info is needed... at minimum a picture of the wheels, but it would be better if we had diameter, width and offset... as well as what type of Lexus it is going on...
Old 08-08-11, 09:21 AM
trickz
trickz's Avatar
my car 2001 Lexus gs300
slightly pulled rear fenders and shaved
front frender shaved.
here the pics of the rims.
19x9 in front
19x10 in rear
5x120 lug pattern i have adapters to fit the 5x114
Attached Thumbnails Need help with tire size and other-73210_802543045516_37525243_42220663_1052613_n.jpg   Need help with tire size and other-2mc7wgi.jpg   Need help with tire size and other-5122515347_1f9769739f_b.jpg
Old 08-08-11, 09:33 AM
mitsuguy
mitsuguy's Avatar
with those offsets and wheel widths, you are probably going to have to run pretty narrow tires, like that car... those are probably 235/35-19 rear and 225/35-19 front... at this, it may still rub... get the thinnest adapter you can, for sure...
those wheels should be +24mm offset... take your 1" spacer and you are at -1mm offset... going to be hard to fit, but the more positive you can get it, the easier it is going to be...
Old 08-08-11, 10:51 AM
zig@tr
Former Sponsor
zig@tr's Avatar
That 1st picture looks shopped and judging by rear fender flares on the 2nd and 3rd photos you need way more than a slight pull to make that work. Those fenders on the 3rd photo are some major body work. I would let those wheels go and keep your sanity.
Old 08-08-11, 03:01 PM
mitsuguy
mitsuguy's Avatar
here ya go... http://www.stancenation.com/2010/06/...oasts-vip-duo/
Wheels:
junction produce scara japan
19×9.5 +20 225/35/19 falken fk452
19×10.5 +24 245/35/19 falken fk452
using that as a baseline, and seeing that his fenders are rolled and pulled quite a bit, you are going to need another inch, give or take...
Old 08-11-11, 07:12 AM
sputniknyc
sputniknyc's Avatar
or you could dump the adapters and redrill. Keep the stock bmw offset.
Old 08-11-11, 05:59 PM
trickz
trickz's Avatar
pmed you...
Old 08-17-11, 02:13 AM
wald.sc400
BANNED for ripping off other members
wald.sc400's Avatar
hey trickz, spoke to you yesterday on the potential trade but after doing some research, and with the 25mm adapters, the offset will be -1. they are 19 9/10 +24 all around. meaning there would be significant poke, dont get me wrong, i love poke when and if the tires are stretched and not stock sized. anyway, i'll hit you up to see if you're down to do some test fitting.
Old 08-19-11, 12:54 AM
trickz
trickz's Avatar
yea i sold the adapters im keeping the rims and getting different adapters so i wont have to modify mine, and im getting some new tires
v1ck4432
07-04-14 12:15 PM
lieup
06-06-12 11:03 AM
kamikaze04
12-12-11 12:10 PM
doodledo82
GX - 1st Gen (2003-2009)
05-24-11 08:14 AM
tuterz
02-18-04 03:53 PM
Quick Reply: Need help with tire size and other
