Vibrations?
Old 09-19-02, 09:49 PM
ken
ken's Avatar
Default Vibrations?
I changed the rims on my SC 400. Now i notice a shaking or vibration at about 67 to 70 mph. over that speed and there is no shaking. I'm still using the Pirelli tires that were on the car and the rims were all balanced. Any ideas on the cause for this problem?
Thanks Ken
Old 09-20-02, 12:00 AM
GS4Will
GS4Will's Avatar
usually the cause is tyre/wheel out of balance.
try to located a shop with hunter machine and pay for a speed balance act.
if it still does not work, you might need to check for bend rim
Old 09-20-02, 02:08 PM
RalAegidius
RalAegidius's Avatar
Are the new rims the correct offset, etc.? I've heard that sometimes they need spacers to fit correctly.
Ral
Old 09-20-02, 03:09 PM
SoCalSC4
SoCalSC4's Avatar
If you purchased an aftermarket cast aluminum wheel, they probably have a larger centerbore (also called "pilot hole," this is the hole in the backside of the wheels that fits over the hub) than your Lexus, so the wheels will not be hub-centric.
This may cause the wheels to mount on the car somewhat eccentically, causing a vibration.
Make sure the wheels have the little plastic O-ring installed in each center hole. For the Lexus, the size is 60.1mm. The wheels should be balanced with these installed, and mounted on the car with them installed.
With the heavier cast wheels, sometimes the radial runout or weight disrtribution of the wheel is such that you may never get them to stop shaking, in spite of high-quality spin balancing.
Unfortunately, the Lexus vehicles are particularly sensitive to wheel or tire imbalance. That's why Manaray & I are advocates of buying high-quality aftermarket wheels...
What did you put on yours?
Old 09-20-02, 03:14 PM
GS4Will
GS4Will's Avatar
excellent info...thanks
Old 09-20-02, 04:21 PM
ken
ken's Avatar
Question
The rims I put on are Vault,a good looking wheel but maybe I should have gone for a better quality wheel?
Old 09-20-02, 04:27 PM
GS4Will
GS4Will's Avatar
ken...not sure about the wheels that you have, but the maker and quality of wheels play an important role...i have seen bad wheels that needed so mnay ozs of lead weight and the shop still could not get them properly balanced..:eek:
Old 09-20-02, 06:05 PM
ken
ken's Avatar
Thanks for all your help. I am going to get the wheels balanced again and see if that works,if not I'll have to make a decision on what else I can do. I didn't have the vibration with the Lexus factory rims on.
Old 09-21-02, 11:29 AM
KILLERGS4
KILLERGS4's Avatar
I had exact same problem! I had rebalanced my rims/tires package I got from wheelmax.com at a local tire place, and they couldn't fix it. So I took it to Lex dealer, and sure enough they fixed it. It cost 190 bucks. On the road balancer. They usually don't do aftermarket, but you have *****!
Old 01-05-04, 05:36 PM
airahcaz
airahcaz's Avatar
What model Vaults, and what size? Did you ever get it to work?
Jake
02-12-15 01:30 PM
chrisvr6
GX - 1st Gen (2004-2009)
15
07-13-10 05:47 AM
tomtsops
10-15-07 07:08 PM
Bluegs300
01-31-07 12:48 PM
skull791
05-15-03 09:59 PM
Quick Reply: Vibrations?
