Reverse Mount Face of Rim?
Old 07-30-11, 02:29 PM
Languistic
Languistic's Avatar
Default Reverse Mount Face of Rim?
Just picked up some 3 piece work wheels, +42 offset in front and +44 in rear. Someone said that I would be able to reverse mount the faces of the rims to get a lower offset? I was not too clear on what they meant.
Old 08-03-11, 02:12 PM
Yes
Yes's Avatar
The face is bolted to the barrel on a 3 piece wheel. I'm guessing they meant that you could unbolt the face and rebolt it on behind the mount, but I don't see how that's possible. You could get new barrels with more aggressive offsets, but that's expensive. Or you could just use spacers. Here's how a 3 piece wheel is put together, btw...
Old 08-04-11, 05:27 PM
onihc
I heart Honda
onihc's Avatar
YES. reversing will lower your offset.
inner lip becomes the outer lip.
Old 08-05-11, 02:09 PM
Yes
Yes's Avatar
That makes sense if the inner barrel is polished. Or if you have it refinished. Most I remember seeing have been raw metal.
Old 08-05-11, 08:54 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
yah, and most wheels doing that would end up with a hugely negative offset... if an 11" wide wheel has an offset of +35, and you do this, our new offset should be -35... thats almost 3" difference, so, for the above mentioned wheels, your +44 offset would become -44 offset, or a difference of almost 4"
something tells me you don't have room under the car for a -44 offset wheel, of any width...
swaangin
01-02-21 09:30 AM
kseipel
09-19-11 08:49 AM
Languistic
07-31-11 11:04 PM
tl.nguyen
08-24-10 07:26 PM
tmasta
08-29-08 06:41 AM
Quick Reply: Reverse Mount Face of Rim?
