WORK Wheels - New 2011 Model (6 New Wheels)
WORK Wheels Released 6 New Model For 2011 !
Meister M1R, S1R, Gnosis HS201, HS202, Emotion 11R-FT, Varianza A6S
WORK GNOSIS HS201 and HS202
The Gnosis HS201 features a thin 12 spoke design, perfectly suited to pair with any luxury sports coupe or sedan. This wheel is offered in a large range of sizing: 19x7.5 ~ 19x11.0 (Full Reverse), 20x8.0 ~ 20x11.0 (Full Reverse), 20x8.0 ~ 20x11.5 (Step Rim), 21x8.0 ~ 21x10.5 (Step Rim). Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Custom bolt patterns available in any range between 5x108 & 5x120.65.
The Gnosis HS202 features a unique curved mesh design, which provides versatility to complement almost any vehicle. This wheel is available in 19" & 20" applications: 19x7.5 ~ 19x11.0 (Full Reverse), 20x8.0 ~ 20x11.5 (Step Rim). Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Custom bolt patterns available in any range between 5x108 & 5x120.65.
Wheels are built using 2 piece construction utilizing a low pressure cast center disk with spun forged barrel. Wheels are available in both Full Reverse barrel or Step Rim barrel. With the entire Gnosis lineup, this wheel utilizes the new redesigned lip flange. The new lip flange has a machined barrel finish along with a formed rim edge for added strength.
Due to its two piece design, you can customize offsets within 1mm increments, allowing for fine tuning of wheel fitment. In addition, two piece wheels are stiffer and suitable for track use. As one can expect with WORK Wheels, there is a wide range of widths and customization options to choose from.
With a completely redesigned center disk, the brand new WORK Meister S1 R brings a new generation of style while keeping the heritage of the Meister series.
The brand new WORK Meister M1 R adds a clean mesh design to the Meister series, while meeting the current demands for larger brake clearance of popular vehicles.
The WORK Meister S1 R & M1 R are both two piece construction wheels, using low pressure cast center disk with a spun forged barrel.
The USA Exclusive WORK Emotion 11R-FT features:
1) 18x10.5 Sizing: The 11R-FT is the first Emotion series to have a 10.5" width in the 18" sizing.
2) USA Exclusive Finishes: Matte Gray Silver (MGS) & Matte Gunmetal (MGM) are standard finishes on this Emotion 11R-FT.
3) WORK Flowforming Technology (spun forming): The key benefit for flow forming is able to reduce the barrel thickness, thus reducing the weight of the wheel without compromising the strength of the rim barrel. The 11R-FT is a good choice for motorsports racing use or at area where there are smoother roads. Unlike our competitors' flow forming wheels, WORK flow forming wheels start with low-pressure cast construction, whereas some of our competitors use lower quality gravity casting.
4) Big Brake Clearance: Due to the design of the 11R-FT, it is very brake friendly to large OEM calipers along with many aftermarket calipers.
5) Reduced Weight: By using WORK Flowforming Technology, WORK Wheels was able to save on average ~2.2 lbs. per wheel, while maintaining the engineering strength and integrity.
RavSpec
Club Lexus Vendor Marketplace
04-05-11 10:09 PM
RavSpec
01-16-11 07:48 PM
