New Tires 98 gs400
Old 08-12-02, 06:00 PM
gratful
gratful's Avatar
Default New Tires 98 gs400
Looking to replace my 16" Continental with a higher performace, quiet riding, long lasting tires. What size is recommended? Suggestions are welcomed.
Old 08-12-02, 07:05 PM
rominl
exclusive matchup
rominl's Avatar
i always suggest the bridgestone so3
Old 08-13-02, 12:10 PM
vroman13
vroman13's Avatar
Unhappy Quiet Tires
This is a sore spot with me and this car. I am running 17" on mine and have found poor results with Falken, Bridgestone and Yokohama AVS dB. Out of the bunch, the Bridgestones were the quietest but lousy mileage. Falkens were choppy. Yokos are on now and are ok. Alignment and balance is very critical.
There are several threads regrading tires, you may want to look them up and read other peoples experience. The 16's should not be as hard on tires as the 17's are. If I were to buy again, I would try Michelin Pilots next.
In summary, my opinion is that the problem with this car is that it runs lots of caster and tends to toe out. This sets up a good handling car, but being so heavy, it causes choppy wear on the inside front edges which lead to alot of noise. Under braking, the tires toe-out more and cause the wear. This is apparently is common with luxury sport sedans, and is exasperated by wide tires.
Good luck,
Old 08-13-02, 12:20 PM
MikeM
MikeM's Avatar
I have Dunlop SP Sport 5000 on my 99 GS400. I did research at tirerack.com before I bought. These are good year-round tires. Much better than the stock Goodyear tires. Not as good as the high performance tires, but I didn't want to spend the money for snow tires and high performance tires. Check out the other threads for high performance tires.
I have 25k on the dunlops and they still look good.
Old 08-13-02, 12:48 PM
rominl
exclusive matchup
rominl's Avatar
i thought the bridgestone so3 have pretty good treads?
Old 08-13-02, 01:07 PM
Wally
Wally's Avatar
I would check into Toyo Proxes. Not sure which model would fit the 16" specs, or how they are in colder climates, but then neither are a concern for me. They are tremendous tires for the $!!!
Old 08-15-02, 04:37 PM
whitels
whitels's Avatar
I second the motion. I have the same tires, have had Yoko AVS dB, too.
Old 08-16-02, 04:10 AM
Princeton
Princeton's Avatar
I have Dunlop SP Sport 5000s as well. (225/16). Would have skipped the snows that I also have if I bought these first. Excellent all around tire.
Old 08-16-02, 08:15 AM
MikeM
MikeM's Avatar
If you have snow tires I'd suggest checking the sport 9000. They are summer tires only but should be great.
Old 08-17-02, 07:51 AM
Guru
Guru's Avatar
I use the SP5000's (17 inch). They work reasonably well as a 4 season tire but do tend to squeel a lot on dry pavement. No replacement for a proper summer tire. I like the Toyo T1-S although the AVS Sports and S-03's are also good.
Old 08-19-02, 01:24 AM
GS4Will
GS4Will's Avatar
new yokos avs es100...
ephisig764
10-08-11 11:49 AM
emacblane
01-22-07 08:39 PM
MSMLexIS
11-17-05 06:01 PM
LexusPia
11-07-05 10:13 AM
04-12-03 11:21 AM
Quick Reply: New Tires 98 gs400
