Good place for custom hub centric rings??
Old 09-20-10, 07:41 PM
BIGMerle
BIGMerle's Avatar
Default Good place for custom hub centric rings??
I need some custom hub centric rings made. 60.10-67.60 Know of any good places?
Old 09-25-10, 12:36 AM
j three
j three's Avatar
Hit Charles up, he is a vendor here and may be able to help you out. I picked some up from him. I think I was the first one .
Old 09-25-10, 01:43 PM
BIGMerle
BIGMerle's Avatar
yeah, I tried and he said he didn't have that size and didn't make them....thanks though!
Old 09-27-10, 03:04 PM
Sltwtrking
Sltwtrking's Avatar
When reading a hub-centric ring size, the description goes O.D. (Outer Diameter - the wheels hub bore) to I.D. (Inner Diameter - the vehicles hub bore). From your description OP (60.10-67.60)there is no possible way this wheel will work on your car without machining the wheels hub bore out.
If you ment 67.60-60.10 I don't believe anyone makes a ring in this size. You can purchase ring size 67-60.10 which should do the trick. It's important to remember that hub rings and the hub bore are not load bearing. Hub rings are used on non hub centric wheels to center the wheel properly. A properly centered wheel once torqued down will not cause any vibrations.
t2d2
11-24-14 11:56 PM
jbone29
05-22-14 03:37 PM
topman
04-23-08 01:06 PM
alredxiii
06-15-06 08:57 AM
Quick Reply: Good place for custom hub centric rings??
