Slotted v.Crossed Drilled v.Blank OEMs
Old 07-17-10, 08:45 PM
BigLexx
BigLexx's Avatar
Default Slotted v.Crossed Drilled v.Blank OEMs
Before I joined CL I was a guest on a number of car forums,and it seems this is one topic that sparked alot of debate. The conclusion that I got from the debates were 1. unless you were driving a High/Sports performance vehicle, SL/CD rotors were a waste of time. 2.If you had Luxury sedan then Premium OEMs/Blanks were just fine. It seems as though the brake pad arguement was not as complex.I wanna get CL members opinions and advice,as I'll be looking to upgrade my brake within the next few months. One thing that I've decided to do was get SSbrake lines,and I'll stick with Ate SL.6 brake fluid as I have used it when I had my 97' Accord.
Old 07-18-10, 03:41 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
unless specifically designed for it, it seems that there is a higher percentage of brake rotor failure at the track when said rotors have been cross drilled...
on the street, probably no issue at all though...
Old 07-18-10, 03:56 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sheer performance:
blanks, some would say a slotted rotor depending on your pad.
looks: slotted, do NOT buy drilled as they will eventually crack, even in street conditions.
Old 07-18-10, 04:19 PM
SChema
SChema's Avatar
I would just use blanks, you made the right decision in using SS lines.
If you want more in depth info, read the attached pdf.
File Type: pdf
stevelifts
10-31-19 11:19 AM
LexiGS4ty
Suspension and Brakes
04-02-12 07:09 PM
JohnEd
02-23-07 06:10 PM
BigRich
01-11-02 08:16 PM
Quick Reply: Slotted v.Crossed Drilled v.Blank OEMs
