Gram Lights
Gram Lights
Hi I have a set of gram lights titanium finish in 19/9 +0 and 19/10 -15 offsets would these fit an 07 is350 ? i know it will require some work on the quarter panels but to what extent ? They are currently on my z and I had to do a roll/pull.
Looking to buy an 07 is350
Negative offsets will not work on your IS350 without serious fender modifications combined with negative camber and streched tires.
If you want to buy new, I would take a close look at the Konig AfterBurn.
Discount Tire Direct has $100.00 off this model with the purchase of a new set.
Depending on your suspension set-up and how aggressive you want to go, the 19x8's are also available in a +30mm offset and the 19x9.5's are available in +25mm offset. The sizes linked above are ideal for stock suspension.
^^ sorry man, but the Konig afterburns are ugly as hell... period. There's no way i would go from authentic titanium-lip Gram Lights to fake, crappy titanium-lip Konigs.
OP... you'll need a lot of pull and repainting of the fender to make those bad boys fit!
nMeOnE
Wheels, Tires & Brakes Forum
01-19-10 10:53 AM
