4lb tire weight saving - impact on performance?
If I were to reduce unsprung weight by 16 lbs (4 lbs for each tire) by switching to a lighter load tier 93Y vs 97Y, what would that do for performance?
I think you'll see some benefit, provided the performance level of the two tires are comparable, acceleration and brakng should improve.
http://www.caranddriver.com/features...sted-tech_dept
Maintenance Moderator
It depends on the vehicle...
The heavier the vehicle, the less effect it will have...
Shaving 4 lbs per tire on your relatively heavy GS460 will make little difference...
Shaving 4 lbs per tire off a stripped down Miata that is outfitted for auto cross, big difference...
You probably will not notice the difference in your car at all...
RacerLex
Wheels, Tires & Brakes Forum
03-17-07 08:39 AM
