IS300 rims on a 99 ES300
Old 03-04-10, 09:34 PM
QuachmanES
QuachmanES's Avatar
Default IS300 rims on a 99 ES300
Recently picked up some 17" OEM IS300 rims, and want to make sure they fit.
I've done some searching around, but I still have a few questions.
I've read that I will need a 10mm spacer, so I'm assuming I will need a spacer with the built in studs. Will the stock studs that fit through the 10mm spacer fit into the IS300 rims, as in the recesses on the back of the wheel? Or will I need to replace the stock studs with longer studs? I'm currently looking at the 10mm Version 1 Ichiba spacers.
Will I need shorter lugs than the stock ES300 lugs to make sure they don't stick out past the rim?
Any issues with rubbing w/ spacers when there is weight in the back of the car, with the stock suspension?
Do they clear the brakes/caliper?
Planning to mount 215/50/17 Bridgestone Potenza RE760 Sports on them.
Sorry for all the questions, I'm a newb at this. Any help is much appreciated.
Zen470
02-18-14 05:50 AM
RITlexus96
11-24-13 08:26 AM
JLip03
17
03-16-11 03:31 AM
QuachmanES
04-08-10 09:24 AM
JimsGX
07-27-09 06:10 PM
Quick Reply: IS300 rims on a 99 ES300
