Need Recommendation for IS250 AWD - Mix and Match Tires?
Old 02-28-10, 06:25 PM
RU514
RU514's Avatar
Default Need Recommendation for IS250 AWD - Mix and Match Tires?
I currently have Dunlop SP 5000m All Season Tires (the stock tires that came with 07 IS250 AWD -- 225/45/17). I have 15K mileage on the tires but my front two tires both have a bubble through the sidewall so definitely time to replace.
My rear two tires are in good shape though.
Anyone recommend what All Season tire I should get and whether I need to replace just the front two or do I have to replace all 4. Can I mix and match tire brands on AWD with same dimensions?
Thanks.
Edit: I probably should add that I'm looking for good performance in snow but relatively smooth/quiet ride as well.
Old 02-28-10, 06:41 PM
laobo979
laobo979's Avatar
continental ExtremeContact DWS i heard they pretty good all season and snow rated tires. most people dont mix the brand they stay with the same all four wheels.
http://www.tirerack.com/tires/tires....um=245WR7ECDWS
Old 03-01-10, 01:44 PM
RU514
RU514's Avatar
It has great reviews. Thanks for the recommendation.
Old 03-02-10, 07:45 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
if you run a tire of even a slightly different diameter (no two models or brands, or even new vs worn are the same), then you run the risk of damage to the drivetrain...
Old 03-25-10, 08:26 PM
RU514
RU514's Avatar
Just want to update this thread...
I purchased 4 new Continental DWS tires and so far they are great. I have put about 500 miles on them and they already have been through snow, rain, and dry conditions. Smooth ride for the most part even at high speeds and they do take hits from potholes.
A lot of places have 225/45/17 out of stock so if anyone needs a place to buy them in stock PM I'll show you the site. It is a little higher priced than TR and Discount Tire but at least they are in stock at this size (and other sizes as well)
Old 03-27-10, 06:05 PM
laobo979
laobo979's Avatar
let me know how the are after a few thousand miles im thinking of those for my winter tires also
Cobra19
12-16-16 02:14 PM
jbm622
11-25-13 07:32 AM
Cobra19
10-05-12 05:33 AM
is250al
01-14-08 02:29 PM
backghost
07-27-07 01:49 PM
Quick Reply: Need Recommendation for IS250 AWD - Mix and Match Tires?
