Rust on my 3 piece rim bolts.
Old 10-21-09, 06:38 PM
sputniknyc
sputniknyc's Avatar
Default Rust on my 3 piece rim bolts.
havent driven my car for quite some time and noticed the bolts on my 3 piece wheels are rusting. Any good way to remove the rust without disassembling the rim?
Thanks!
Old 10-21-09, 08:30 PM
Spyder78
Spyder78's Avatar
I would say some sort of cleaner and a brush. And when cleaned spray some clear coat to prevent buildup in the future.
Old 10-22-09, 11:28 AM
sleeper408
sleeper408's Avatar
I would say it depends on how far the rust has penetrated the metal. I think if it is only slight rust on the top layer of the metal, you can probably wire brush some of it off and clean it, then spray a protective layer. You should have a professional wheel shop look at it. You don't want it to rust all the way then when the time comes to disassemble the wheel the bolts can't be removed.
levie
SC- 1st Gen (1992-2000)
23
06-14-12 07:28 PM
GS3loco
04-13-09 08:49 AM
chrispy
25
01-27-08 06:33 PM
mjr24
03-17-04 12:35 PM
lexguynj
07-31-01 02:35 PM
Quick Reply: Rust on my 3 piece rim bolts.
