this should fit right???
Old 04-18-02, 11:45 AM
gsstud
gsstud's Avatar
Question this should fit right???
20x9 +37 for the fronts, 20x10 +43 rears..with eibach lowering springs..
Old 04-18-02, 11:47 AM
gsstud
gsstud's Avatar
sorry!! here are the tires...245/35 pzero, 275/30 pzero
Old 04-19-02, 01:59 AM
Manaray
Manaray's Avatar
I think your front might rub...it's a close call...the rear is fine...but know that you're running undersized tires and you're wheels/tires will have a rounded or "angled" sidewalls...some people like this look (because it gives maximum lip) but some don't...
On the rear wheel, you MIGHT be able to fit a 285...MAYBE...
Old 04-19-02, 03:32 AM
tinygs
tinygs's Avatar
Default Re: this should fit right???
With a 19x10"+43 w/275 tire using Eibachs(same spring I use) you would be fine. But, using 20x10"+43 you better cross your fingers. If it clears it will be by 1-2mm's tops.
As Manaray said, a 275 isnt optimal for 10" width though, and 20x10" +43 w/285 tire will most likely rub. If 20" is the ticket for you, the tried and true is 20x8.5"F and 20x9.5"R.......
Old 04-19-02, 04:34 PM
gsstud
gsstud's Avatar
Thumbs up
thanks for your info!! i guess ill find out next thurs. thats when the wheels will be in..
Old 04-19-02, 06:03 PM
link13
link13's Avatar
+37 on a 20x9 is perfect- any more inboard, the 20" tire may rub the suspension upright. Guys who have run 255/35zr20 have typically had to gring the bolt just above the front tire (ball-joint bolt, connects the upright to the upper control arm).
Be sure to post pics!
(SoCalSC4 using his bro's computer)
Old 04-20-02, 06:17 AM
Manaray
Manaray's Avatar
SoCal, won't a 255 on a 9" +37 rub the outer lip of the fender? Or are you talking about running a 245?
Old 04-20-02, 09:49 AM
GS4Will
GS4Will's Avatar
very informative
how about:
19x9 +39, 19x10 +39
or 19x9 +43, 19x10 +43
which one would be ideal with 245/275....1.38" drop F and 1.18" drop R? or would 285 R rub at all?
thanks guys
Sherwink
RC - 1st Gen (2015-present)
01-18-16 04:23 AM
egmmbah
Suspension and Brakes
01-08-15 06:29 AM
bklynjoker
06-01-12 09:25 PM
ScKcBc
01-15-10 10:09 AM
LEXISM
18
02-26-04 09:45 AM
Quick Reply: this should fit right???
